Headlight bulbs
Headlight bulbs
Hello! I'm a new member, having joined today. I have an '02 SC430 that needs a low beam bulb on the driver's side. The car is in the body shop so I have the headlights out of the vehicle. I can easily get all the bulbs out with the exception of the low beam. There is a gray circular cover that has arrows and "Open/Lock" stamped on it. I can't turn it. Is this how I access the bulb for replacement?
Thanks!
John
Thanks!
John
Thanks, iolmaster! The '02 must be different than the '06(?) There are no clips. Just a large round gray cap that has the words "Open/Lock" stamped on it. I've attached a photo of the assembly and really appreciate anyone familiar with the procedure to replace the bulb to give me some direction. (I don't want to damage anything) Thank you!
'02 headlight assembly
My cap seems to be stuck. I don't want to force it and break anything. Is there a trick to loosening the cap? Or do I just exert whatever pressure is necessary to rotate it counter-clockwise? Thanks!
peppertree
10-28-19 11:17 AM
skytribe
02-26-19 05:08 PM
jashtiani
11-10-15 06:50 PM
HustleHard
SC- 1st Gen (1992-2000)
12-25-05 01:32 PM
