Techstream
Old 06-09-16, 05:56 AM
Scarletti
Scarletti's Avatar
Originally Posted by theazz
Guys
I received my techstream but can't get the computer to install the drivers.
I'm running win 10.
Theazz
There are a few guides out there for XHorse 64bit Driver install routine.
I used this one, so whilst it's not the best written set of instructions it does work
So, best uninstall and follow the guide from the start. Ensure you use the Firmware update routine to check that the driver can talk to the cable and read the firmware level, as per the instructions.
Probably no need to download the software from the dropbox link, assuming you already have the software on the supplied mini-CD. I did a comparison between my mini-CD and that link (and also another members on this forum) and there was no difference apart from the Techstream application itself, which is the least important bit tbh. YMMV.
Old 06-11-16, 03:11 PM
iolmaster
iolmaster's Avatar
Guys
I'm running win 10.
Theazz
If you are running W10 you likely have a 64bit computer. The drivers will not load automatically. You have to do it manually. There are instructions on how to do that on this site.
Old 06-14-16, 05:55 AM
Defratos
Defratos's Avatar
Can someone help me here.
I've installed Techstream and have the cable and everything is working fine.
Just one question, in the start-up menu I get the below selection to choose from:
Firstly "Radar Cruise" Which I select as my car has the PCS system and radar thingy.
Secondly is asks me to choose from a bunch of numbers, I have no idea what they are, I thought they could be the year of the car or something but I just always choose the last one "1008-"
Can someone tell me what those number stand for and which one I shoudl select?
Old 06-14-16, 08:03 AM
Scarletti
Scarletti's Avatar
Interesting! (well, it was till I realised you have an IS-F not an SC430!)
Well, there are only four options to choose (<808, 808-908 etc) so why not select each one in turn and see which works? Probably quicker than waiting for an answer!
Alternatively just deselect Radar Cruise, unless you're trying to trouble shoot that specific ECU?
Old 06-14-16, 10:26 AM
Bgw70
Bgw70's Avatar
Does techstream select model and vehicle or do you?
If you are selecting everything, techstream may not be working correctly.
Also, can you run diagnostics etc.?
Old 06-15-16, 02:57 AM
Defratos
Defratos's Avatar
Techstream select the vehicle model by itself.
I just have to choose Radar Option and then those numbers.
Even if I deselect the Radar (i.e. no radar) i still have to select one of these numbers.
as mentioned above I usually just pick the last one.
Everything seems to run fine, diagnostics, data logging etc..
Old 06-17-16, 04:45 PM
Defratos
Defratos's Avatar
Bump, no one knows what those numbers are for?
Old 06-17-16, 05:08 PM
Scarletti
Scarletti's Avatar
Numbers that are specific to an IS-F... and you're asking on a SC430 sub-forum... and you're wondering why we don't know?
My guess is there are 4 variants of the Radar Cruise option. Perhaps the invoice from the dealer will tell you which one is fitted, or look in the service documentation for clues.
Old 06-18-16, 12:38 PM
Defratos
Defratos's Avatar
Fair point, I just found this thread using the search and figured it was some generic number that everyone knows.
Thanks for the advice though
Old 06-18-16, 03:23 PM
GmanSC
GmanSC's Avatar
How can you tell what version the firmware is? Browsing online, they just list the software version.
Old 06-18-16, 03:38 PM
Scarletti
Scarletti's Avatar
There is a utility program supplied "FirmwareUpdateTool.exe" as part of the XHorse driver. That will display the Firmware level of the "cable".
Old 06-18-16, 11:29 PM
GmanSC
GmanSC's Avatar
My question was how do you know what to purchase since the sellers don't tell you what version firmware it has?
Old 06-19-16, 05:40 AM
Scarletti
Scarletti's Avatar
Ah!
You ask the Seller via messaging before you buy.
Also, when you order you put a message to the seller stating what you want/need. If they break the terms of the "contract" you can (in theory) claim (Amazon, Ebay & AliExpress all make it fairly easy to resolve).
Old 06-19-16, 06:28 AM
iolmaster
iolmaster's Avatar
http://www.aliexpress.com/item/Origi...248128688.html
If you look at the Hardware version is states version 2 0 4. This is the latest It is the firmware version.
Old 06-19-16, 08:41 AM
MikeSC430D
MikeSC430D's Avatar
Like many folks I have an older Dell laptop hanging around with XP on it. So far most of the old files were deleted and most programs uninstalled. WiFi is disabled and it will not be connected my local internet, so not much chance of getting nasty things to mess up the system. My techstream has yet to arrive. I'll let you know how the driver install goes.
Quick Reply: Techstream
