Brake bleeding and fluid level
Hi,
So this morning I bleed the brakes using mityvac. After the first short drive ~15 mi, I checked and found that the fluid dropped 1 cm. I topped up and took another short drive. Dropped another 4 mm.
After the third drive, it stopped
dropping. I checked before topping up there is no leak.
Why did this happen?
One way seals? Reservoir?
There is a certain way to bleed this car and if I remember correctly, it has to do with the electric pump.
The fluid level, increases and decreases as you drive then park the car.
If the fluid level does not continue to leak then you should be okay.
BTW, do the brakes feel good?
Strange thing happened:
Last night art the end it dropped another 1 mm.
This morning I went to check for leaks, the level is way above max (reservoir full) Where does fluid usually go in this car?
When you first turn on the key, listen for the pump while you jump out of the car and watch the level go down in the master cylinder. The pump is very loud and will run for a few seconds.
