Advice on a B2510 Convertible Top problem?
The only reason you would have for changing the entire assembly is if there is some kind of damage in the hinge assembly like loose fasteners or something caused by metal wear. Passenger side motor requires an Allen wrench cut down to access one of the three bolts holding the motor to the gear assembly. Its pretty simple.
Paul
Paul
Here is how I did it. Literally a "Write up" with no pictures. Hope it helps
https://www.clublexus.com/forums/sc4...etty-easy.html
