Gas Cap
Old 08-09-16, 12:40 AM
Lesly1
Lesly1's Avatar
Default Gas Cap
Hi fellow members. My Gas Cap doesn't close flush to the body. What adjustment can I make.
Thank you.
Chris....From OZ.
Old 08-09-16, 09:23 AM
mandyfig
mandyfig's Avatar
Welcome to Club Lexus. Perhaps a picture will hep us look at it. Please post 1 or 2 pics showing the issue.
Old 08-09-16, 10:53 AM
Harold57
Harold57's Avatar
Lesly, do you mean the gas cap door, rather than just the cap?
Old 08-09-16, 04:34 PM
Lesly1
Lesly1's Avatar
Hi, yes the Gas Cap Door. When closed , the back part sticks out about 1/4," instead of being flush to the body.
Chris......From OZ.
Old 08-09-16, 05:15 PM
Harold57
Harold57's Avatar
It looks like the locking mechanism on the body has a (plastic) nut on it that you might could loosen and then attempt to push it back farther into the gas filling recess. But I haven't tried it.
Old 08-09-16, 08:43 PM
texsexlex
texsexlex's Avatar
....it's been some years back, but Lexus did have an issue with the gas cap mechanism,the plastic piece inside the door is the culprit. I don't know the part # off hand, but it should be easy to find & hopefully it's still available
Old 08-10-16, 12:50 AM
Lesly1
Lesly1's Avatar
Thank you, I will look into it as soon as the weather is more favourable.
Chris.
Old 08-11-16, 02:12 PM
DshngDaryl
DshngDaryl's Avatar
Here is the post that Texsexlex was probably referring too https://www.clublexus.com/forums/gs-...ure-issue.html
Old 08-11-16, 04:42 PM
Harold57
Harold57's Avatar
It sounds like that link you listed DashingDar refers to a problem with the door not latching or closing.
I think that Lesly is saying that his door will latch but it sits proud of the side after it is latched. If I understand both situations, they are different problems.
Old 08-11-16, 09:52 PM
texsexlex
texsexlex's Avatar
...good search Dash, this is the thread that discusses the issue. I have the same issue & planned on doing the fix awhile back, but never got around to it.
Old 08-11-16, 09:57 PM
texsexlex
texsexlex's Avatar
...hey Harold, I think you may have misunderstood his post, it does state that he can close the door,but it doesn't fit flush......the op for this thread has the same issue also
Old 08-12-16, 04:34 AM
Bgw70
Bgw70's Avatar
I had this problem and one of the two screws were missing. See two screws on the left side of the gas door. When I installed the second screw, it made the door flush again.
Old 08-12-16, 06:12 AM
Lesly1
Lesly1's Avatar
Hi Bgw 70, when you say one of the screws were missing, did it have two screws to begin with & one fell out, or did you drill & fit another one. I only have the bottom screw. No hole where your top screw is.
Chris.
Old 08-12-16, 02:07 PM
Bgw70
Bgw70's Avatar
Chris.
hey Chris,
mine had two holes and I thought a screw was missing...when I removed the single screw I saw a place on the metal part for a nut. I went to my Lexus dealer and he gave me a screw and I provided the nut. Hope this helps.
Old 08-12-16, 02:33 PM
Harold57
Harold57's Avatar
No, I understood, I think (depending on which "his" you are referring to ). Lesly can close his door but it doesn't sit flush. However, in the link, it sounded like the owners were not able close their doors (wouldn't latch) and were banging on it to get it to close. Maybe I misunderstood them and the door just didn't close flush but still latched?
Quick Reply: Gas Cap
