Rear Brake Issue
I have noticed that my rear left brake caliper is biting into the rotor harder than the other three on a sudden application of the brakes. Causing the car to skew and I hear a loud thump, of what I think is the locking up of the caliper. Happened to me more than once.
I also noticed that the rotor on this left side shows more wear (where there is now a lip) than the right rear.
Anybody has experienced this? What could be causing this uneven braking?
I have to tear it down and see what and why it is doing this abnormal braking.
Any ideas?
Thanks.
Any ideas?
Thanks.
Perhaps one caliper (the hard biting one) is working correctly and the other one is weak due to sticking or possibly air in the line? Could also be the master cylinder since it feeds the RH and LH sides separately.
Any ideas?
Thanks.
Any ideas?
Thanks.
It sounds like you might have a sticking brake caliper and it does clamp and retract like it is suppose to. (It stays clamped or partially clamped) If you had work done recently it may be a just a twisted brake hose.
Here is a Scotty Kilmer You Tube Video on what else it maybe. (damaged caliper pin)
Good video. Right to the point. I think he left one important step out. At appx. 1:59, he put grease inside the caliper. Good. But I would've inserted a wire brush in their first, in order to remove any residual corrosion, just to be safe.
I will check out the video and will plan on tearing down both rears soon. Thanks.
Any ideas?
Thanks.
Any ideas?
Thanks.
Thanks for the feedback Sp. On moderate braking no issues. Once I slam it, I can feel the rear left bite and the rest of the car skews. And it slams. From zero bite to full on almost lock up.
