Bluetooth knowledge?
Old 09-01-16, 09:35 AM
biggrendel
biggrendel's Avatar
Default Bluetooth knowledge?
Hey all...
I am awaiting delivery of my 2006 pebble beach edition SC430.
i would like to listen to music via blue tooth. (from iphone) I know this has been discussed in other threads... but i'm not sure what my 2006 needs or has.
can anyone help me out??
much thanks!!!
-Lance
Old 09-01-16, 11:19 AM
Poqman
Poqman's Avatar
The 2006 does have BT pairing for a phone, but not for streaming music. BTW, the ability to import contacts, input contacts or edit contacts is useless. About the best you can expect is handsfree answering the phone.
Old 09-01-16, 11:25 AM
biggrendel
biggrendel's Avatar
Thanks for the response...
is there a decent way to get bluetooth connectivity for music? or .... do i need an aux wire? what would you recommend?
Old 09-01-16, 03:14 PM
Harold57
Harold57's Avatar
Yes, most folks use Vais to add extra inputs and I believe BT also.
Welcome to the forum.
Old 09-01-16, 03:16 PM
mandyfig
mandyfig's Avatar
I have the VAIS and I added the Bluetrip and I have BT streaming and phone use.
Old 09-01-16, 03:21 PM
Harold57
Harold57's Avatar
Mandy, isn't there a thread or two with a DYI on adding the VAIS?
Old 09-01-16, 11:51 PM
GmanSC
GmanSC's Avatar
Not true. I imported the phone book fine. For the SC 06+ owner with Navigation and Samsung phone, here is what to do:
1. Park car outdoor. Call some number to establish the connection.
2. Hit setting on the SC. Scroll down, hit transfer phone book. Wait for the message "send phone book".
3. On the Samsung, hit contact.
4. Hit EDIT (left button on the bottom).
5. Select Share name card via
6. Hit .select all
7. Hit Done and wait for the transfer screen on the SC. When the screen comes back to the phone book page, you are done.
8. Check the phone book.
That's all to it.
Old 09-01-16, 11:58 PM
GmanSC
GmanSC's Avatar
Originally Posted by biggrendel
Hey all...
much thanks!!!
-Lance
You can get the Bluetooth Cassette Adapter from Amazon or Ebay for about 20 bucks, then pair your phone. Worked fine for me.
Old 09-02-16, 05:10 AM
Poqman
Poqman's Avatar
I'm glad that worked for you. I tried with an old Samsung phone, but now use an Apple. No luck for me. Any secrets how to manually add a contact or manually edit a contact in the list?
Old 09-02-16, 06:09 AM
Poqman
Poqman's Avatar
I added the VAIS Tech SL3B BT to have the ability to stream music using BT. Works great, but a little expensive. You have to pull your radio to unplug a harness and plug in their adapter harness. It's all plug n play so no cutting wires. There are several installation threads if you do a search. I find it's worth the money. The audio quality is great.
Old 09-02-16, 07:40 AM
biggrendel
biggrendel's Avatar
will this work?
https://www.amazon.com/Bluetooth-str.../dp/B00VAQTVBC
and if so... could one of you nice folks point me to the installation video mentioned above! -Big thanks for all the help!
Old 09-02-16, 09:55 PM
GmanSC
GmanSC's Avatar
will this work?
Save yourself 200 bucks and time, just buy this item. Work great.
https://www.amazon.com/ION-Audio-Cas...ssette+adapter
Old 09-10-16, 05:12 PM
biggrendel
biggrendel's Avatar
Hello all... so i got my Vias ... could someone point me to a installation video?
Old 09-10-16, 05:53 PM
sideswipe
sideswipe's Avatar
Use this video to remove the dash, then follow the instructions provided with the unit. did my install last night.
https://m.youtube.com/watch?v=xWAOLSJnOVc
Poqman
10-24-15 11:58 PM
marcygarb
10-20-14 07:03 AM
aTeAse
10-16-13 07:12 PM
bimori
10-22-07 06:37 AM
JohnnyCake
03-07-07 08:51 PM
Quick Reply: Bluetooth knowledge?
