Starter Replacement Adventure
Old 11-07-16 | 03:44 PM
  #31
DshngDaryl's Avatar
DshngDaryl
Originally Posted by Bon
I've ordered my parts through Amazon and the grand total is $156 plus coolant.
The starter is all new parts and it's the "Quality-Built 17748N Supreme Import Starter" an Amazon premium brand item.
The intake manifold gasket set is the Beck Arnley 037-6183 Intake Manifold Gasket Set.
The rear water transfer gaskets (2 req.) is Beck Arnley 037-6183 Intake Manifold Gasket Set.
The throttle body gasket is Beck Arnley 037-6183 Intake Manifold Gasket Set.
Hey Bon,
Not to be a pain, but are all the gaskets that are needed included in the one Beck Arnley Gasket Set? Is the Throttle Gasket separate? I only ask because I went to order the parts you used and noticed they were all the same part number.
Thanks for all the help you have given me so far. I really appreciate it.
Daryl
Amazon Amazon
Old 11-07-16 | 06:34 PM
  #32
Bon's Avatar
Bon
Originally Posted by DashingDar
Hey Bon,
Daryl
http://www.amazon.com/Beck-Arnley-03.../dp/B009NQ8L5I
No problem at all, and thanks for catching the error. I went back and corrected the mistake. The correct part number is "Fel-Pro 35941 Water Outlet Gasket" and you do need two of them. Also the throttle body gasket is Fel-Pro 61281. I'll be out of the country for a couple of weeks so good luck on your repair!
Old 11-08-16 | 07:57 AM
  #33
pynky01's Avatar
pynky01
My 2006 has 62000+ miles : thanks for this information.. i will have some knowledge of what is happening if this occurs: then I will panic .. I did replace, solo, a steering column on a 1990 Oldsmobile 98 Brougham and actually drove it for a while... .
mickeyt
11-24-16 05:05 PM
cbibb
04-21-11 01:06 PM
jcastaneda
02-02-11 10:46 AM
DSM2GS400
09-23-10 12:34 PM
whoster
12-21-07 02:41 PM
