2003 Lexus SC430 timing belt observation
After I purchased a 2003 SC430, with 174,000 miles, I started to wonder about the timing belt! The more that I wondered the more nervous I became! I had the Carfax and there was no mention of the timing belt ever having been changed! Next I went to the nearest Lexus dealer and they printed out all of the information that they had on my car! Again there was no mention of the timing belt having been changed. They did spot the there was a crack in the radiator that was leaking coolant! After that I was afraid to drive the car until the timing belt was changed and a new radiator was installed. I got the name of a local mechanic who worked for a local auto shop but also did side jobs at his house. He changed the belt and the radiator for less than half of the price the dealer quoted me. Of course the old belt looked just fine but at least I can sleep without worrying about that!
If not being personal, what did it cost to have it done?
My mechanic said it would take 3 hours to do the job at a cost of $ 1,000 with parts & labor.
I also couldn't find records as they don't keep them after 10 years. (so I was told)
My SC has done 160k Kilometers 100k Miles. The belt should be changed at 90k miles.
Chris....From OZ.
Chris....From OZ.
Chris,
Typically in the states you will pay $400-650 in labor for the job, dealerships would charge $1000-1500. If he can do your timing belt in 3 hours then he definitely knows his way around these engines. Most mechanics would take 4-5 hours to do a typical timing belt service.
Chris....From OZ.
Chris....From OZ.
Chris....From OZ.
Chris....From OZ.
The first thing that the mechanic is going to do is to remove one of the covers & see whether the timing belt has been changed or not.
I am going to be there myself so that I can see how it looks & take it from there.
Chris....From OZ.
Chris....From OZ.
Usually, there is a sticker affix on the inside of the hood that will tell you whether the TB has been changed and when. Look for it.
Got the car back today. After one of the Timing covers were removed, we were able to tell that the Timing belt had NOT been changed.
For the whole Kit, Belt, Water pump, etc., plus labor (4 Hours) $ 1,000. The Trans oil didn't look the best so I had it Flushed + new Filter for $250.
Now, seeing that I had an Oil, & Oil Filter plus Air Filter done a couple of weeks ago I can say I feel much safer.![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Chris......From OZ.
Chris......From OZ.
Chris......From OZ.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Chris......From OZ.
I just got off the phone talking with the mechanic. NO, it was not connected to any power flush machine.
He told me that he took off the pan, emptied all the oil, & kept pouring in fresh oil until it was all clean.
New filter & gasket & filled it up.
Chris.....From OZ.
Chris.....From OZ.
