Help, which wire or fuse in the trunk is accessory power?
Old 10-29-16, 07:21 PM
jzdulexus
jzdulexus's Avatar
Default Help, which wire or fuse in the trunk is accessory power?
I would like to tap into accessory power in the trunk(when key is in 12v comes on). How do I get that? Thanks alot for your help!
Old 10-29-16, 11:06 PM
GmanSC
GmanSC's Avatar
Remove the trunk lining, there is the fuse box on the driver side. Remove the box cover, there is an empty socket for the relay. Use your ohm meter find out the 12V pin. I used this for my NavTool, It's much easier than tap into the wire bundle of the Nav unit. Sorry, I don't have the picture to show.
Old 10-30-16, 10:35 AM
ShawnOk
ShawnOk's Avatar
<br /><br />I tried those same spots in the trunk fuse box using an "add-a-fuse" for my amplifier but I believe they are constantly "hot;" correct? This might lead to a battery drain depending on what you might be powering. Just a thought from my experience. Please correct me if I'm wrong.
Old 10-30-16, 11:34 AM
Bgw70
Bgw70's Avatar
This may help, let me know if you want a pic of a specific circuit.
Old 10-30-16, 03:45 PM
jzdulexus
jzdulexus's Avatar
Thanks a lot guys! I finally found the acc power in the grey wire on the Pioneer unit and managed to insert a wire in the slot to tap it. Now I just completed my installation of backup cam with Naviks. It was not easy, but probably well worth it.
Old 10-30-16, 08:31 PM
GmanSC
GmanSC's Avatar
You are correct. I thought the pin I used is "key on", turned out, it's not. I ended up spliced to the DVD 18 pin connector: pin 18 (gray wire).
SOLID300
Performance & Maintenance
06-05-22 07:55 AM
samene
11-04-18 05:09 PM
D3V3LOP3R
02-04-15 09:45 PM
sidwin
10-09-12 11:47 AM
Superjatt
SC- 1st Gen (1992-2000)
07-25-11 07:01 AM
Quick Reply: Help, which wire or fuse in the trunk is accessory power?
