Headlights
Old 10-30-16, 09:44 PM
Caflashbob
Caflashbob's Avatar
Default Headlights
how difficult is it to change out the low beams?
Old 10-30-16, 10:26 PM
texsexlex
texsexlex's Avatar
....you'll basically have to drop the front bumper, then remove the headlight(s) to get to the bulb.
Old 10-31-16, 06:38 AM
Coleroad
Coleroad's Avatar
I did mine without removing the headlights. The right side was pretty easy after removing the airbox. The left side I unbolted the ecu box to let me move it a few inches bac. It was very tight but gave me enough access to get the job done. Not saying it's better or worse, just another option.
Old 10-31-16, 07:01 AM
iolmaster
iolmaster's Avatar
I did not have to drop the bumper. I do have small hands and that was a big advantage. Someone at some point said the 06 to 10 were easier than the 02 to 05. I do have an 06. I am not sure this is true. edit: I am sure I have an 06, not sure about the other.
Old 10-31-16, 08:27 AM
Coleroad
Coleroad's Avatar
And mine was an 03.
Old 10-31-16, 10:33 PM
texsexlex
texsexlex's Avatar
I've actually done mine both ways, but after the time spent moving airbox/ecu & trying to fit my hand into the small space, it was just as easy to drop the bumper.....plus less cursing...lol
Old 10-31-16, 11:00 PM
Caflashbob
Caflashbob's Avatar
p
how? What kind of fasteners
Old 11-01-16, 06:17 PM
texsexlex
texsexlex's Avatar
.....if I remember correctly, all the fasteners are the plastic screw in type......I'm not in front of the car, so I'm going off the top of my head. There are screws on the top bumper cover & grill, these are located under the hood. There are also screws located under the car, which are used to connect the bumper cover to the splash pan & there are a couple of screws located behind the front wheel liners (you'll have to move these out of way,to gain access to the screws).....after all are removed, you should be able to remove bumper cover or pull it out far enough to access to the headlights..........hope this helps some & sorry that I can't be a little more detailed, since I'm not with the car right now. If anyone else possibly has pics, this might be of some help also
Old 11-01-16, 06:47 PM
Golden95SC
Golden95SC's Avatar
Are you simply talking about removing the low beam bulb and changing them out?
Extremely easy. Just twist and they both come straight and re install
Old 11-01-16, 07:10 PM
Caflashbob
Caflashbob's Avatar
Yes just the bulbs
Old 11-02-16, 12:16 PM
KingReyes
KingReyes's Avatar
Just did mine yesterday on an 06. You have to drop the bumper to do it properly. God I hated it. Headlights has 4 bolts; 1 of which is located behind the bumper panel, just above the fender.
Old 11-02-16, 12:32 PM
iolmaster
iolmaster's Avatar
Not sure what you mean by "properly" I did my 06 without dropping the bumper and they work just like it came from the factory.
Old 11-02-16, 01:16 PM
Coleroad
Coleroad's Avatar
If by properly you mean not have to squeeze and contort your hand around to do it. I didn't have much of a problem, but I do have small hands. If I had big mits I'd go ahead and pull the bumper.
Old 11-02-16, 03:21 PM
Caflashbob
Caflashbob's Avatar
Dealer quoted $195 flat rate today
Old 11-03-16, 04:48 AM
iolmaster
iolmaster's Avatar
Including the bulbs?? Or just labor?
zrzsky (04-23-20)
Quick Reply: Headlights
