Battery
Old 11-07-16, 02:34 AM
Bgw70
Bgw70's Avatar
Originally Posted by GmanSC
Shawn, you're absolutely right. I thought I used "key on" 12v but I didn't. I wonder if Bgw has same problem since he also tapped into a constant 12v.
i have the Beatsonic setup. The only power I used in the trunk area is for the backup camera and I tapped the power for the camera in the box in the trunk.
the Beatsonic power was made in the console and it is all key on.
Old 11-11-16, 07:40 PM
GmanSC
GmanSC's Avatar
So I tapped into the gray wire (pin 18) of the Nav DVD connector to get the +12V for the NAVIKS. Charged the battery overnight to full voltage and thought everything would be OK. To my surprise, the battery went dead again. I bough this Interstate battery just two weeks ago at Costco, so I brought it back and exchanged for another one. Now everything is OK as should be.
It turned out the battery was defective.
Old 11-14-16, 05:01 PM
Caflashbob
Caflashbob's Avatar
Originally Posted by Caflashbob
most batteries fail from plate warpage. Shorts the cells out.
agm batteries plates are mounted in a solid material. Hard we to warp
east penn changed their plate mounting system several years ago and now can also pre charge the internal plates and is able to now test them prior to installation in the case.
i was in the fancy Rv biz for 32 years and a remote area user so the best engineering and quality is necessary.
mk/deka from east penn are acknowledged to have less failures and have a longer cycle life.
seems the largest auto parts place is my local source for the deka/east penn batteries under the Bosch brand.
smart of them. $120 range for a sealed lead acid. $150 for Agm.
My other engines all have mil grade optima spiral wound red tops for starting.
unfortunstely optima does not make a h6 group 48 battery.
and east penn does not make a gel that size
probably because the charging voltage is different for a gel. And was made to be run down to 50% and then back to 100%
not a car use.
had the battery tested today. Rated at 770 tested at 847CCA
Bosch(deka) Agm
car turns over very quickly
2GR
01-05-20 06:43 PM
SNiiP3R
10-24-16 08:29 PM
WylieKylie
05-18-14 09:39 AM
Matsui
GX - 1st Gen (2004-2009)
21
02-09-14 05:26 AM
bacardi
03-10-11 10:13 AM
Quick Reply: Battery
