Can you wire a backup camera & a relay into the NAV screen instead of using Navicks?
Bgw70, which pin, if any, changes electrical status when the dashboard screen is opened? Does it switch to +12V, or to ground, for instance? That would let me turn on my backup camera when I ope n the screen cover.
Tom
Many of us wanted to do just that but have not been able to. May be you can find the way. Let's know.
Which lead powers the nav system in the trunk? Can I turn off the nav system in the trunk from the dash, with the motor running? By closing the screen cover door? A second-grader's refrigerator light problem, isn't it?
Yes, you can turn off the NAV, just close the door.
It will not open again until you push the OPEN button.
i still don’t fully understand how you want it to operate.
ie. Just a backup camera or a constant rear camera when driving.
if you want a constant camera while driving, Darryl posted a video showing this operation with the open button.
Here is the PDF how to.
https://www.clublexus.com/forums/sc4...tallation.html
BGW, I watched the video on YouTube yesterday regarding the back up cam and radio installation using Beatsonic, the installer had to remove the back seats and ran the wires from the trunk to the front, my question is, if you just need a back up cam, do you have to remove the back seats?
Go with the Naviks. It’s not that difficult. If I have to do it again, probably take about hour and half. The new Naviks has improved and upgraded.
Beatsonic is a unit that allows an aftermarket head unit for the audio to integrate with the amp and speakers for the SC430. Beatsonic unit is housed behind the head unit in front. So it has to run wires to the back to the video input.
If just doing backup camera there would be no reason to take out the back seats because the unit is all in the back, nothing goes in the front at all. Video to the DVD box and from there to the NAV screen
https://www.clublexus.com/forums/sc4...007-sc430.html
Beat sonic is not what you want if only wanting the rear view camera. Beat sonic is primarily for replacing your audio head unit and want to use the stock amp and speakers. It has a rear view camera option and would need to run wires to the back. But for only rear view camera Beat sonic is not the thing to get. Beat sonic is always placed behind the audio head unit in the front and never in the back.
Yes you can just work in the back of the car. It is pretty simple, just need the interface to do it with.
gazi001
RX - 1st Gen (1999-2003)
09-23-14 04:14 PM
