I seem to be having bulb problems lately! The drivers side rear marker light went out this week and I don't know how to get to it in order to change the bulb. I had both knees operated on and I can't bend down or get on the ground tofigure out what is required! Thanks!
I believe that you have to get to the bulb from the back. You have to go through the fender well to get at it. I have not had to do mine but I remember others having to do this.
Hi Dylan
If your knees are bad you will have to get someone to do this for you.
We don't have lit side markers in the UK, but I did this to paint mine body colour. 1. remove the arch trim with a Philips screwdriver. 2. Peel back the arch liner 3. remove 10mm bolt 4. remove bottom clip from bumper 5. pull the bumper away, change bulb, job done.
