ignition shut off
Old 01-25-17, 12:06 PM
mkotoole1
mkotoole1's Avatar
Default ignition shut off
My ignition shut off after trying to start the car will a "dumb key" I tried my regular smart key but the ignition seems to be locked I called a dealer and he suggested to lock and unlock the door a couple of times but this didn't work.
any suggestions???
Mike
Old 01-25-17, 12:12 PM
mrblister
mrblister's Avatar
any suggestions???
Mike
You need to provide better information ? Ignition shut off does that mean the car wont start . Does the engine turn over ? The keys required for the sc430 all have a chip in them to hand shake with immobilizer [ smart ? ] Can you provide more details of what the symptoms are
Old 01-25-17, 01:14 PM
mkotoole1
mkotoole1's Avatar
any suggestions???
Mike
Further to my message using the "dumb Key" the engine turned on twice but quickly stopped running. I realized that I probably didn't have the key card close enough to the ignition for it to continue to run. When I tried with the key card close to the ignition there was no response. ignition was on, lights worked but the engine would not turn over. I tried with the smart key and also could not get anything. It seems the immobilizer is engaged even though the light stops flashing when I engage the key to the ignition which implys that it is working properly.
Old 01-25-17, 01:31 PM
mrblister
mrblister's Avatar
[QUOTE=mkotoole1;9749689]Further to my message using the "dumb Key" the engine turned on twice but quickly stopped running. I realized that I probably didn't have the key card close enough to the ignition for it to continue to run. When I tried with the key card close to the ignition there was no response. ignition was on, lights worked but the engine would not turn over. I tried with the smart key and also could not get anything. It seems the immobilizer is engaged even though the light stops flashing when I engage the key to the ignition which implys that it is working properly.[O
The dumb key is this your flat wallet key ? If yes then the holder is where the chip is . You have to hold it against the ignition or
keep it close to it. Then turn key. Does the engine crank but not start? Did you try using your regular [ smart key ] and hold the plastic wallet key holder close to the ignition switch.
Old 01-25-17, 03:13 PM
Harold57
Harold57's Avatar
First off, welcome to the forum mkotoole1.
Please provide a little background information. Did you just buy the car? What year is your SC430? What are you calling the "dumb key"? Is it the plastic wallet key that mrblister is referring to or is it the valet key (it is a metal key but has no buttons)? Is this a new problem or has it just started happening?
Old 01-26-17, 02:43 PM
DshngDaryl
DshngDaryl's Avatar
You can try disconnecting the battery for a few minutes and see if that resets the immobilizer.
Old 01-26-17, 03:24 PM
Bgw70
Bgw70's Avatar
any suggestions???
Mike
Welcome to CL Mike...which key are you referring too.
wordwrkr
12-15-16 06:50 PM
bmorekid
03-21-15 08:06 PM
99GSoc06
10-05-11 07:30 AM
kdub159
07-20-10 12:21 AM
Butta
07-24-05 09:33 PM
Quick Reply: ignition shut off
