sc430 ecu
sc430 ecu
I have a sc430 2002 and about a month ago the fuse for the dash had to be replaced. After that time the only way I can get the dash lights and the gauges to work is to unhook the negative battery cable for about 10 seconds. Once the cable is replaced the gauges and lights will work again until the car is shut off for approximately a hour then I have to go thru the who process of unhooking the battery cable again. As long as the car is running it works fine it is only if it is shut off for a period of time. The battery is fine and all fuses check good. Any ideas
I took a look at ebay and it turns out that you can buy a used cluster for $49. I would consider doing that, so you can see if it is a problem with the cluster (which is my guess) or a problem with the wiring/computer. You could probably consult a cluster specialist, but I think it would cost you more than $50.
http://www.ebay.com/itm/2002-Lexus-S...VWtAHX&vxp=mtr
I agree, that sounds like a good approach DashingDar. Something probably died or shorted out causing the fuse to blow.
Welcome to the forum larrysc430.
Hey Larry, were you ever able to resolve your problem?
Hello, not sure anybodies going to be reading this here, but i'm only looking here because ive got a 2002 sc430 with a dead dash, nothings working on it and the cars stuck in limp mode.So when i see something which might be similiar, i get excited...
so ive just read the other guy here has just had his dashboard fuse replaced, CAN ANYBODY TELL WHERE THE DAHBOARD FUSE IS. ive got all 5 fusebox diagrams for thencar andive never seen the dashboard fuse - does it even exist?
reagards steve
reagards steve
JGWentwrth
09-17-18 04:30 PM
tmf2004
09-09-13 09:09 AM
