Charging Warning light came on
the pulley was turning didn't have something to keep it from turning so I could get the bolt off (but I was underneath the car) I got on top of engine took filter and something else off and got the bolt to turn ,I hope I can get it back on with no problems would you know the torque specs for that bolt it's a 17mm
I definitely couldn't remove the alternator without removing the PS pulley. there is a hole on the PS pulley, jam a wrench in there so it wont turn then use a socket to remove the nut.
that was my problem but its off, got alt off almost got my face smashed getting it out, now the fun part putting that back in, is there any torque specs for the bolts?
after i replaced the alternator, the plastic clip on the wire harness broke into pieces. Got a new one from amazon and didn't use butt plugs, i unpinned the wires from the old clip then pinned them on the new one. Just letting you know in case you come across this issue.
TRENTIMUS
GS - 1st Gen (1993-1997)
01-31-19 03:41 PM
masboy
03-04-12 06:37 AM
