Worth an offer?
Old 03-30-17, 04:24 PM
kevin3344
kevin3344's Avatar
Default Worth an offer?
While I'm waiting for my 2002 SC430 to be delivered from Florida, I saw this one listed locally. Do you think it's worth an offer? I don't mind owning two for a while! Higher miles than I would like but the timing belt / water pump have been changed.
Old 03-30-17, 04:56 PM
jzdulexus
jzdulexus's Avatar
If its local you can check it out in person. There is a wide range of feel and condition of a car that affects its value. There is a some difference between 2002 and 2006 even in how it drives. Only you can tell if the difference is worth the premium. 2006 is much more difficult to find in general and if features like internet access on the radio matters to you then 2006 has a big advantage.
Old 03-30-17, 05:54 PM
kevin3344
kevin3344's Avatar
Thanks, I'll check it out tomorrow. I was checking out the service record on LexusDrivers.com and the last entry says this:
Service: RIGHT REAR STRUT (LEAKING)
description: RIGHT REAR STRUT (LEAKING) ~ ~ ~ ~,CUSTOMER DECLINED SERVICE -CUSTOMER DECLINED WORK AT THIS TIME
Not sure how much that will be to have replaced?
Old 03-30-17, 07:51 PM
JohnnyCake
JohnnyCake's Avatar
At a Lexus dealership, both rear struts, shocks, and strut mounts support assembly: $1,137 parts $559 labor = $1,697.30
You probably want to look at ball joints/control arm also ($830)
There will be a bunch of replies saying what a rip-off the dealership is (which is true) and how you should either (a) do it yourself; (b) go to Toyota; or (3) go independent.
But, for better or worse, this is what the dealership charges.
Old 03-31-17, 04:36 AM
Bgw70
Bgw70's Avatar
Internet access, did you mean it has Bluetooth, which allows you to answer calls, but I do not think you can play music.
Old 03-31-17, 07:44 AM
mrblister
mrblister's Avatar
The 2006 has gen 4 navigation and blue tooth just like the 2005. You can make and receive phone calls that's it. If you want to play your music from your phone you will need a via unit,
[QUOTE=Bgw70;9820087]Internet access, did you mean it has Bluetooth, which allows you to answer calls, but I do not think you can play music.[/QUO
Old 03-31-17, 08:58 AM
jzdulexus
jzdulexus's Avatar
What I mean by "Internet access" is the ability to add another dedicated digital input on the 06 radio so that it can play unlimited MP3 music and thousands of radio stations on the internet. Specifically, accessories like Grom addon is advertised to work only on 06 and after. Since I have not tried it on 05 and before years I do not know if extra digital input is possible.
Old 03-31-17, 09:08 AM
Bgw70
Bgw70's Avatar
i see what you mean now.
others have added aftermarket devices with the stock radio that allow phone connections and backup cameras on the early models too.
i personally went with the beatsonic and pioneer radio but still have the OEM radio on a shelf.
retro showed us how to connect an external audio connection where you can play music etc from his phone through the 2002 radio with the help of an aftermarket adapter, but he is the exception.
BTW, retro is now my neighbor but I have not met him in person yet. He is still getting moved in!
Old 04-01-17, 10:10 PM
texsexlex
texsexlex's Avatar
.....what a good neighbor to have...lol
Old 04-02-17, 12:18 PM
jonas's RX
jonas's RX's Avatar
I have a little less miles on my 02(45K)and should have many more years of fun :0
You really can't go wrong with the SC ! I personally would rather pay a bit more but get a clean one
Old 04-03-17, 09:13 AM
kevin3344
kevin3344's Avatar
Now that is one clean car! Wow!
johnk73
GX - 1st Gen (2003-2009)
24
02-20-18 02:06 PM
Adamski
12-31-14 07:55 AM
txtanner
09-20-14 01:49 AM
SWOman
04-08-12 11:24 AM
mdawg630
02-10-11 02:51 PM
Quick Reply: Worth an offer?
