SC430 body panel question
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/20170416_151543_7ec7c1715919465537223d27718ccce958c7f8e3.jpg)
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/20170416_151532_66fd35113ce2ce5ad3f412aa9ae1d3797bc43125.jpg)
I damaged the body component on the passenger side just below the door on my step mom's 02 SC430 ( the narrow strip that runs from Wheel to wheel).
I have tried to locate the part online with negative results. Can anyone point me in the right direction or at least give me a part number question mark I have attached photos below of the body component I damaged.
Thanka to all!
Any body shop will have this info and cost to replace.
I found this from Lexussouthatlantaparts.com Different part numbers for different colors.
Part Number: 7585124071A0 ; 7585124070; 75851-24070MOULDING, BODY ROCKE; WHITE PEARL CS.,065
MOULDING, BODY
MOULDING, ROCKER PANEL, RIGHT. WHITE PEARL CS..
MOULDING, BODY
As OTMike said, it is called a Rocker Panel. Based on the age of the car, you will probably be better off buying one from a salvage yard.
If you are not going to do the work yourself, you should just have the dent fixed by a body shop. It will probably cost you about the same.
Looking at the picture, you might be able to do the work yourself. It looks like three screws and a bunch of snap on clips.
