2002 SC 430 loose good latch problem
Old 04-18-17, 10:14 AM
hankinla
hankinla's Avatar
Default 2002 SC 430 loose good latch problem
Hi guys hope you're all well I wanted to reach out to anybody who's had problems with a loose closed hood.
The hood falls and closes straight down however there is a little bit of play when it was locked there's anybody have a quick fix for this ?
The impact is when I drive occasionally I'll get some small squeaking from the hood and it's kind of annoying as you can imagine . Thank you very much for reading this far if anybody has any ideas at all on how to direct me to a resolution that will be much much appreciated
Old 04-18-17, 11:13 AM
mrblister
mrblister's Avatar
There should be a small amount of adjustment in the latch or the fastener. There should be enough to adjust you should be able to use shims to raise or lower either fastener if necc.
Old 04-18-17, 05:00 PM
hankinla
hankinla's Avatar
Thanks but I can't see where the shims or adjustments can be done? Here's a pic! Thoughts?
Hood latch on frame of car . Where can adjustments be made?
Photo of latch on the inside of the hood. Where can play be adjusted ?
Old 04-18-17, 05:14 PM
Coleroad
Coleroad's Avatar
If you loosen the bolts that hold the latch ,you can slide it up and down a little.
Old 04-19-17, 11:07 AM
mrblister
mrblister's Avatar
I agree on loosing bolts .
Old 04-19-17, 01:03 PM
Bgw70
Bgw70's Avatar
And give that piggy engine a good bath after you adjust the hood latch! ;-)
as Cole and Mr. B said...see pic below. NOTE, in. Lbs Not, Ft. lbs
buddhi (07-31-21)
Old 04-19-17, 02:11 PM
DshngDaryl
DshngDaryl's Avatar
Here are a couple of people who explain how they adjusted their hood latches. The second one is a very novel idea, but I'm not sure I'd recommend it
Old 04-19-17, 02:15 PM
DshngDaryl
DshngDaryl's Avatar
Does your hood fit perfectly in it's space but it is just "rattley", or does the front of your hood stand a little low or a little high?
If so, you can adjust the rubber stoppers under your hood. They are usually at the front corners and they screw up or down. For an official explanation, look at step D above
Old 04-19-17, 05:44 PM
Lesly1
Lesly1's Avatar
There's no way in the world I would want the first guy working on my car. All the fiddling around just to adjust the hood was ridiculous. First try the adjusting stops, providing the hood is level to the guards. If still loose, draw a line across the top of the adjuster prior to loosening the bolts. Therefore you have something to go by instead of guesswork. The second video, I don't know what he was on about.
Chris......From OZ.
Old 04-19-17, 09:21 PM
hankinla
hankinla's Avatar
Thanks guys, adjusted rubber stoppers and all set; will fine tune the latch if needed but tiny adjustment, and tight as can be!
Old 04-20-17, 06:10 PM
Harold57
Harold57's Avatar
Glad you got it fixed. Welcome to the forum.
maxmethods
11-02-22 09:38 AM
jonas's RX
08-26-17 10:35 AM
XS_SC300
SC- 1st Gen (1992-2000)
01-06-07 03:01 AM
SC400TT
03-01-05 12:17 AM
Quick Reply: 2002 SC 430 loose good latch problem
