02 SC430 Convertible Flap Not Raising, Causing Problems, Need Fix
02 SC430 Convertible Flap Not Raising, Causing Problems, Need Fix *FIXED*
Hi All,
I have been looking through many threads on this forum, but none that I could find had this exact issue. So, as everyone who owns an SC knows, when you convert your top, the top detaches and when it is about to into the trunk compartment, there is a flap that is supposed to raise to provide the necessary room for the roof to fit.
On occasion, and it seems to be happening even more lately, the flap will not come up and the roof will just try to force its way down with no success, running/forcing the motor the whole time. No damage is done on the outside, but obviously, I don't want to destroy the motor internally. The weird thing is that this doesn't always happen. I have to turn off and on my car to reset the process a couple times until it decides to cooperate and go back up.
Basically, nothing like this would happen if the flap worked every time and I have no idea what is causing it not to flip up at random times. Any help would be greatly appreciated, especially with the warm summer months coming up!
A picture or 2 would help us help with your issue.
Hi All,
https://www.clublexus.com/forums/sc4...-problems.html
Hi All,
Catdaddy (08-02-17)
Sorry for the late response, It's been raining non-stop down here for the past several days and I couldn't drop the top to take a picture until today (below). To reiterate, it has been working 75% of the time, I'm assuming there is something that needs to be lubricated or there's a sensor that's out of place or loose? Anyone know where to look or know if there may be some dangling wires that aren't rotating properly?
Also, did you look at the thread link I posted earlier?
Thank you both for pointing to the motor, but when it does work, the motor on mine is quite strong, showing no signs of struggle. The problem has to be something internal either blocking the process or not identifying that the roof is to the point where that flap needs to raise.
Furthermore, I checked inside the trunk and found the following was out of place, could this be part of the issue, as it might be getting stuck since the wire is out of place?
The difference between the left and right clearly shows there is a harness that is guiding the wire away from interfering. However, without a schematic, I can't tell if this is even related to the component I'm mentioning.
Hey Catdaddy
Click here => https://www.clublexus.com/forums/sc4...t-close-2.html
They had the same question about the package tray motor cable being off track, however the news was not good for them because the resolution was not as simple as they had hoped
If that is the case with you, click here for more detail => https://www.clublexus.com/forums/sc430-2nd-gen-2001-2010/848956-convertible-top-problems-5.html
and look at post 67. The PDF's will tell you a whole lot about the Package Tray Motor.
Catdaddy (04-27-17)
Now THAT sounds familiar. Sorry you're having this problem too. It's quite embarrassing when it happens because it's like flipping a coin or rolling the dice. Can anyone please elaborate on what may be causing the motor to go, but not perform?
I meant no offense, I guess I'm just trying to exhaust all options before resorting to major repair. Will resetting that wire in place (without tape) fix it. It sounds like maybe the tape was the cause of the repair defect, as it is not as flexible.
