batt low after 3 or 4 days of sitting in garage
Old 07-07-17, 07:34 PM
Tycer
Tycer's Avatar
I find that if I leave my key in the ignition while in the garage the steering wheel and seat will sometimes not go to park position and that is when I notice my battery goes dead.
Old 07-13-17, 05:54 PM
Propulsion
Propulsion's Avatar
Can I use a Battery Tender to maintain the electronic settings while swapping out the existing battery for a new one? I don't want to lose my settings and I certainly don't want a trip to the dealership to reprogram them.
- Also, any recommendations on a new battery for a 2006 GS 300 AWD. I heard Napa's batteries are decent.
Cost is not an issue, I want dependability when it's needed most.
Thanks
Old 07-16-17, 07:58 AM
Harold57
Harold57's Avatar
A battery tender should work. You might be able to do the same if you are able to switch over the cables very quickly keeping the no battery power to the car time very low. The car won't lose its memory instantly but will after a few seconds. (Note: I've never tried or timed this.)
Old 07-16-17, 10:52 AM
GmanSC
GmanSC's Avatar
Thanks
The things you will lose are the clock, the seats setting and radio stations. All of those just need minutes to program. I don't think the battery tender will work.
Old 07-17-17, 09:36 AM
JohnnyCake
JohnnyCake's Avatar
I don't think you lose the radio stations, but I could be wrong.
Old 07-17-17, 01:05 PM
ned1
ned1's Avatar
Originally Posted by kengonz
hi i heard some one ask me that question when we first bought our sc. told us about the same problem with his sc. we didn't have that problem cause we just got car and it was cold to ride my bike but!!!!! it's riding weather and the car sits for 3 or 4 days and I have to put a battery charger on it and as long as i drive it every other day its fine.
what can i do to stop this the batt is only 2 years old?
I've noticed that if I leave my heads lights and fog lights in the "on" position (which turn off when locked w key fob) I have a slow parasitic battery drain over several days. So when I'm parking the car for a few days I just click them off. If I'm daily driving np! So far so good! I thought I read that fix on here somewhere?
Old 07-17-17, 01:38 PM
Propulsion
Propulsion's Avatar
What about the key fobs? Will they be affected if the battery is disconnected for a few hours or perhaps a day?
Will the key fobs required reprogramming after changing batteries?
Old 07-18-17, 12:30 PM
Bgw70
Bgw70's Avatar
the short answer is no and no.
you will be good to go! ;-)
Propulsion (07-18-17)
Old 07-20-17, 07:36 AM
Bgw70
Bgw70's Avatar
I just went on vacation for 13 days, returned home thinking the SC430 would not start. To my surprise, she fired right up!
NOTE: I don't have the OEM radio, but not sure if that is unit causing the load.
i have an Autozone Duralast Gold battery
Old 07-21-17, 07:14 PM
Prasha
Prasha's Avatar
True, after 15 years of ownership, I say sc430 start is unreliable, Lexus has not attempted to identify the cause or fix it.
Old 07-21-17, 10:02 PM
RichardMor
RichardMor's Avatar
This is the cut-off switch I use in the Avanti. But we've had no problems with the SC, so I'm not going to install one if or until there is an issue. This switch is also a kill switch for any shorts:
Old 07-22-17, 12:08 PM
Prasha
Prasha's Avatar
Posters here have made several suggestions, This high end expensive sc430 has electrical design flaw, other than is a perfect car. Is it too much to expect Lexus come up with official fix? they have the design specs and qualified people to trouble shoot.
Old 07-24-17, 07:36 PM
ShawnOk
ShawnOk's Avatar
I've added a kill switch to my SC430. I don't have any photos at this moment but will put some up soon. I only disconnect when I'm leaving two for more than two weeks. Up to about a week and half my car will start without a problem. I am using an Interstate MTP Megatron battery. I also switched all my lights to LED's (interior and exterior) and have noticed that I no longer noticed the parasitic drain which is notorious in our cars. Also, heard that leaving the headlights on "Auto" drains the battery. Thus I always turn the headlights to off when parked for many days.
http://www.ebay.com/itm/Auto-Battery...53.m2749.l2649
Old 08-01-17, 05:26 AM
hotrodsrj
hotrodsrj's Avatar
Originally Posted by Jabberwock
I have left my 2004 SC in garage without starting for 2 weeks and it starts immediately with no issues with battery. Battery is approx 1 year old.
This is exactly how it's supposed to work! I have left our SC in the garage for months without unplugging the battery and/or tendering it. And the battery is years old. Either there is a parasitic drain (too much) and/or the battery is not full charged or bad/weak cell. A fully charged battery should read 12.65 VDC ideally.. but anything over 12.5 VDC will probably be okay. If you don't have those kind of voltage measurements just sitting.. then the battery is or already is tango uniform! Even a measurement less than 12.5 is suspect. Probably a weak cell.
I would only use a cut-off switch for storage in excess of many months.
SC400slide
SC- 1st Gen (1992-2000)
30
02-28-13 09:00 AM
SystemShok
09-24-12 07:06 AM
ScWift92
Performance & Maintenance
29
01-11-12 06:25 AM
BostonSC4
12-25-09 11:17 PM
sphereman
09-22-02 05:24 PM
Quick Reply: batt low after 3 or 4 days of sitting in garage
