Looking at new wheels...
10th Gear
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Hello guys! Newbie here. Trying to upgrade my wheels form the 'pie-plates'. I'm looking at a set of ESR wheels with the following specs: 19x8.5 all around with a Offset - 30, Bolt Pattern - 5x114.3, Will these wheels work with a stock suspension? Regards. Joe
You could also get rid of the fugly pie plate look by just changing out the center insert section of the OEM wheels. Cost on ebay for a set of twisty inserts tends to be about $100. Makes the stock wheel look much better.
http://www.ebay.com/itm/4x-Wesden-Aftermarket-Silver-Twist-Wheel-Center-Caps-fits-Lexus-SC430-550291S-/282462709574?hash=item41c416e746:g:6JUAAOSwBt5ZDQgr&vxp=mtr
Sc430Lex (07-04-17)
http://www.ebay.com/itm/4x-Wesden-Af...5ZDQgr&vxp=mtr
10th Gear
Welcome to the forum Sc430Lex.
10th Gear
10th Gear
It will be perfectly fine. I suggest you to get the following tire fro your setup: 245/35/R19 or 255/35/R19
caddyowner
03-03-11 03:53 PM
