Headlight lens
My headlight lens covers appear to be scratched on the inside-but I assume this is moisture? Can the lens cover be removed or do you have to remove the entire light?
An adhesive and tabs hold the clear plastic lens on the headlights . You have to bake the headlight to remove the clear lens hopefully you don't break a tab, or worse. Then hopefully you get it water tight when you rebake it , and put the lens back on.
Top Hat
GS - 1st Gen (1993-1997)
120
05-17-09 01:26 AM
rxchick09
01-15-07 01:19 PM
