Parking and front marker light problem
Old 08-07-17, 05:27 PM
NEWONE1
NEWONE1's Avatar
Default Parking and front marker light problem
Hello all...have an unusual problem that's cropped up...my parking lights and front marker lights are not coming on and yet the rear tail lights and marker lights are? I did replace the parking lights with led's and they were working just fine with the front marker lights for months.....just strange that only the front marker lights and the parking lights don't work but all the rest work fine....any help would be greatly appreciated.......yes I did check fuse 13 and it's fine
Old 08-07-17, 05:35 PM
Bgw70
Bgw70's Avatar
did you check the voltage at the fuse or the light socket?
Old 08-07-17, 06:29 PM
NEWONE1
NEWONE1's Avatar
voltage is good...did notice when i turn on lights the parking lights flicker for a second...sometimes they do come on (with front markers), but when i switch them off and turn back on they won't light up again...just baffled how the rear tails and markers work and the front markers and parking lights won't?????They're all on the same circuit...could it be the led's are causing a problem now???
Old 08-07-17, 06:47 PM
Bgw70
Bgw70's Avatar
it is possible the LEDs are causing a problem. What about the ECU for the lights, could it be the issue?
i don't have my wiring diagrams in front of me...did you look at the diagrams?
Old 08-07-17, 07:11 PM
NEWONE1
NEWONE1's Avatar
Thanks Bgw 70...don't have wiring diagrams and not familiar with ecu for the lights..........I'm thinking led's but why now after they were working for months and still do very intermittently??? ( no error codes either)...If I have to pull them, which is a real PIA job..I'll go back to the old bulbs..UGH!
Just doesn't make sense with the way the lighting is working right now....half on half off when they're on the same circuit?????
Old 08-07-17, 07:21 PM
ShawnOk
ShawnOk's Avatar
As I was saying in your other thread about the brake LED's, there's something funny with how the ECU works and its proper set resistance. I have LEDs in the parking lamps and the bumper side markers but I don't have the issues you seem to be describing. My parking lamp LEDs are from ijdmtoy.com and my bumper marker LEDs are from either Advanced or AutoZone (the are a 4LED "honeycomb").
The 168 bump marker LED's look similar to this...
Old 08-07-17, 09:51 PM
NEWONE1
NEWONE1's Avatar
Thanks... I'm pretty sure it's the led's.....could have been for interior use only...........can you give me the product model number for the parking lamps...and if Bgw70 put led driving lamps in what were they......I only want to do this installation one more time...lol
Old 08-07-17, 11:45 PM
ShawnOk
ShawnOk's Avatar
Sorry, I really don't remember the model number of the LEDs I am using as the side marker lights. They look like exactly like the photo I posted. I got them at either Advanced AutoParts, AutoZone, O-Reilly, or possibly even PepBoys. Those are the only stores, I frequent. Try going to each one's website and put in "168 LED," and look for the same bulb as the photo. I will link the parking lamps I purchased from iJDMtoy.
http://store.ijdmtoy.com/168-194-282...s-p/10-006.htm
Truthfully, any product from iJDMToy should work for your issue. Every bulb I have purchased from them has worked without flaw. My entire car is LED, interior and exterior, and I use them for nearly everything (except the parking lamps as I stated before).
Old 08-08-17, 03:12 AM
Bgw70
Bgw70's Avatar
i only installed interior LEDs.
Old 08-08-17, 07:35 AM
NEWONE1
NEWONE1's Avatar
Thanks guys.....I ordered the parking lights,,,,,,,hopefully that's the cause ...if not, back to the incandescent ...
Old 08-08-17, 10:25 PM
NEWONE1
NEWONE1's Avatar
Haven't changed the led's yet but wondering, other than the fuse,are there any relays or ballasts to the parking and marker lights that could be faulting?
NEWONE1
09-01-24 10:07 AM
Downtuned
06-16-24 09:19 AM
garbage85
05-27-08 03:16 PM
ED1
IS - 1st Gen (2001-2005)
07-18-07 11:57 PM
Proven
SC- 1st Gen (1992-2000)
15
01-02-07 02:46 PM
Quick Reply: Parking and front marker light problem
