Lca#2
Lca#2
hi guys
I'm trying to find this part (see picture) online but every time try to search for it
the parts search says it's for another Lexus! (Is or gs) are these parts interchangeable?
thanks in advance
Lex, I gave you the eBay part with the same number you show in that picture. It works for the SC430. I have no idea if it works on a GS.
you need to go to a dealer website and look up the lower control arm 2 for a GS to see if the part numbers are different or you should call a dealer parts dept to ask that question.
it could be physically the same part but probably has a different part number.
If you are looking for the LCA#2 for an SC430, the Lexus part numbers are :
48660-24020 for the right side and
48670-24020 for the left side ( driver side )
I just changed them on my 2004 SC430 and those are the part numbers I used. Fit like a glove, exact replacement part. Here is a link to the Lexus listing :
https://www.mylparts.com/oem-parts/l...Y4LWdhcw%3D%3D
According to that listing, they also fit GS300/400/430 and IS300.
Bgw I tried all the links in this tread and couldn't find the information on the bushings you used
could you post the bushings please
i was told that there wasn't a bushing made to replace the worn out one
thanks in advance
thanks in advance
Bgw I looked on rock auto found nothing put arms,no bushings!<br />do you have a part number on the ones you purchased?<br /> <br />any input would be greatly appreciated <br /><br />thanks in advance <br /><br />whodat!!!!!!!
Here is a link to the Daizen bushing kit for the SC430 :
https://tmengineering.net/webstore/i...e5beecae9effd6
You might need a press to install the new bushings.
Thanks guys I really hope this solves my problems
my mechanic has a press to install them I was told that no bushing where mad to replace
the one in lca#2 so now I can prove them wrong
thanks in advance
thanks in advance
