Cooling fan running a lot
My 430sc 2005 cooling fan goes on with in minutes when I drive my car? Coollent level is fine. Temp gauge is in the midddle. If I drive my car is there any chance I could blow the engine out?
To directly answer your question(s): I doubt your fan is running so soon after start up due to radiator demand, unless you live in a very hot climate (in Phoenix on hot days my father-in-laws Toyota Avalon cooling fans can take only minutes to come on after leaving the garage for example). Your fans maybe running due to the demand of the air conditioner and controlled by a binary pressure switch(s) (full disclosure.. many automotive systems are designed differently and I am NOT intimately familiar with the SC air and they may be sequential or not). or you may have a faulty control switch somewhere in the circuit that is acting up too that is sending a demand signal to come on. So.. it simply could be this protocol for the condition that is turning on your fan(s). Secondly, if your temp gauge is reading normal and everything else looks good, there is no harm in running the SC and no.. you won't blow it up.
One poster mentioned that a fan could be out and therefore that causes an early call for "a fan" however, I don't think a fan being faulty is this problem per se. But, the poster makes a good point about how many fans are running? You actually can see them running and/or hear them running if you raise the hood and stick your ear side to side.. maybe a good thing to do anyway. When we purchased ours this spring... fan health (both function and noise) was one of the things that I made sure worked. I don't know how bad or good these SCs are with fan failures. Perhaps another poster will chime in with their stories.
Hope this helps your concerns.
