80% Throttle
80% Throttle
Is it normal for full throttle to only register 80% throttle on Techstream? I am wondering because it seems I can only get 80% with the pedal on the floor. I have checked and the throttle body butterfly seems to be opening fully at full throttle but can't help but wonder if I am only getting a little more than 3/4 of what this car will achieve. Does anyone know if this is normal?
Thanks
Thanks
Thanks
Thanks
have you tried the throttle calibration procedure?
Hey! Work has been insane so haven't had much time to do much else. I have reset the ECU but it didn't seem to change anything. Is there another procedure? I was just wondering if this was normal? I recently had an input turbine speed sensor go out which I replaced with no issues. But when I was troubleshooting that was when I discovered the 80% throttle thing. I can't find anything in the book that says if that is normal or not.
Well I could certainly connect techstream and see what I read.
so just push it to the floor and observe techstream, is that correct?
also, do you have service manuals?
Yeah, I forget exactly what screen it is on but switch on engine off and push the pedal to the floor. I get 80% throttle. There is also an active graph. I do have manuals.
for now and if you have time, you could check the manuals for the remove and replace procedure for the throttle body. It might have an alignment procedure and what you should be seeing on the TechStream screen.
.....sorry about not being clear, but yes I was referring to the throttle body control. I don't have TechStream personally, but from reading your & other's post, I know that you can change some settings......just curious if it may be possible to change that setting to a higher % ???
Cp2295
11-26-16 12:24 AM
Suneet
12
06-07-07 11:33 PM
