TPMS Testing and Programming with TechStream 2002-2006
Old 09-04-17, 07:24 AM
Bgw70
Bgw70's Avatar
Default TPMS Testing and Programming with TechStream 2002-2006
I know, it's been addressed many times in different ways but I could not find a thread dedicated to Testing and Programming the TPMS sensors in our cars. I am pretty sure this applies to years 2002-2006...
i Am only going to show how to find the bad sensor for now and will show Programming when the new sensor arrives.
Turn on your techstream software, connect the OBDII connector to your car.
Once it detects your car
Select Tire Pressure Monitor from the menu.
onlinegal (06-09-22)
Old 09-04-17, 07:27 AM
Bgw70
Bgw70's Avatar
I had an error code for ID2
As you see, Techstream provides plenty of data from the TPMS sensor. Easy to read and diagnose. The low voltage and extremely high temp was the giveaway this was the bad sensor.
The following 2 users liked this post by Bgw70:
Harold57 (09-04-17), Jabberwock (09-04-17)
Old 09-04-17, 07:33 AM
Bgw70
Bgw70's Avatar
I ordered a new TPMS sensor from a Lexus dealer on eBay.
Here are the four part numbers…old vs new
(Left) Old Lexus part number…(Right) New Lexus Part Number
42607 24010 White 42607 24011
42607 24020 Blue 42607 24021
42607 24030 Red 42607 24031
42607 24040 Gold 42607 24041
Denso part numbers
5500191 White
5500192 Blue
5500193 Red
5500194 Gold
Old 09-04-17, 10:42 AM
Harold57
Harold57's Avatar
Very nice, thanks Bgw!
Old 09-04-17, 11:56 AM
iolmaster
iolmaster's Avatar
Just curious why you are not replacing all of them since one has gone bad. The other three are not far behind. I have an 06 and the next time I get tires I am planning to replace all of the sensors. They are almost 12 years old at this point and I can't imagine they will last that much longer.
Old 09-04-17, 01:07 PM
Bgw70
Bgw70's Avatar
because I replaced one two years ago and now another is going bad...I guess I could go that way but not sure why...
Old 09-04-17, 01:12 PM
iolmaster
iolmaster's Avatar
Originally Posted by Bgw70
bcause I replaced one two years ago and now another is going bad...I guess I could go that way but not sure why...
Does the sensor come with the gaskets etc. or should we get those too? Also, did you find it easier to add 6 lbs. of let out 6 lbs. pressure to register the sensor?
Old 09-05-17, 10:38 AM
beaunoz
beaunoz's Avatar
I tried this procedure this weekend with no luck. Purchased the same sensors Bell Lexus Scottsdale.
The YouTube video I watched (
) is misleading to those with 2002-2006 SC430's as this doesn't apply to our vehicles. After notating all of the sensor ID's I was puzzled when I realized that there was no option to manually input the sensor ID's manually with the TIS TPMS Utility.
Notice how there are no 7-alphanumeric characters within the TIS TPMS Live Data? It only shows the color labels (White, Red, Yellow, Blue). Our sensors are registered by rapidly deflating the tires 6lbs within 300 seconds. I tried deflating a couple times and gave up. Helps to have an air compressor nearby in the event you release too much air.
I've been researching this ALL morning nearly pulling my hair out but at least I know I'm not crazy. I will attempting the deflation method again this evening.
//Beau
Old 09-05-17, 07:05 PM
Bgw70
Bgw70's Avatar
The YouTube video I watched (https://www.youtube.com/watch?v=jrR78PogYw8) is misleading to those with 2002-2006 SC430's as this doesn't apply to our vehicles. After notating all of the sensor ID's I was puzzled when I realized that there was no option to manually input the sensor ID's manually with the TIS TPMS Utility.
//Beau
what color sensor did you purchase?
also, when i registered my first one two years ago, I did the rapid deflation and it registered just fine. Are you sure your letting out enough air.
i think I just kept letting air out until registered.
once I receive the next one in a few days, I will document the procedure again.
Old 09-05-17, 09:59 PM
ShawnOk
ShawnOk's Avatar
I must say that my original set from 2002 are in my winter tires/rims and 3/4 lasted 15 years without replacement. So replacing them all at one time b'c one failed doesn't necessarily mean that others are doomed to fail soon after. Just my experience.
BGW, awesome write up! Hope this works and gives us some direction for these horrible TPMS sensors. In any case, I'm glad you're taking the initiative BGW. If you have time and the foresight, maybe you can please continue the DIY to adding a second set of TPMS (for which the switch in the glove box is dedicated). I would greatly appreciate it. Every season I have to return to Lexus to have them swap the Main for 2ndary, which they just just erase the MAIN and put new numbers every time rather than take the time to do two different sets. So frustrating. Anyway, if you show us how to program both sets, that would be phenomenal. Thanks so much and good luck!
Also BGW, as a side question. Do you have a key code for the TechStream or are you using the "Evaluate" function? I installed mine but don't have/wasn't given a key. Thanks for any advice.
Old 09-06-17, 03:17 AM
Bgw70
Bgw70's Avatar
i know this worked for me on an XP machine.
https://drive.google.com/drive/u/0/m...3M?usp=sharing
programming the sensors is very intuitive and the second set is just like the first set. Techstream provides step by step instructions.
my new sensor has been shipped but not sure when I will see it due to Hurricane Irma!
Old 09-06-17, 07:01 AM
jonas's RX
jonas's RX's Avatar
Dumb Q
Is it easy to reprogram the TPMS yourself ?
the dealer wants like $475 to do all 4 if I recall
crazy..
Old 09-06-17, 07:19 AM
Bgw70
Bgw70's Avatar
Originally Posted by jonas's RX
Dumb Q
crazy..
A Lexus dealer may want more than that and yes, it is very easy.
when the new sensor arrives, I will show you the process to program a new sensor for the 2002-2006 model.
2007-2010 are similar but a little different and there is already a tutorial here on CL.
Old 09-06-17, 07:22 AM
Bgw70
Bgw70's Avatar
it was two years ago, but I think I let air out...I know I just kept letting air out until it registered.
simple and easy.
Old 09-06-17, 10:51 AM
beaunoz
beaunoz's Avatar
I purchased all four for a 2nd set of wheels. You are correct that I likely didnt let out of enough air. I was too lazy to pull out the air compressor hose. But you made a good point about OVER-inflating by 6lbs and then releasing the air. Is 300 seconds enough time to deflate all four tires? Or will I have to keep restarting the procedure when I run out of time?
Quick Reply: TPMS Testing and Programming with TechStream 2002-2006
