04 sc430 throttle body electrical connectors
Need to know what the pigtail connector is on throttle body, it is the 2 wire connector on passenger side
My experience is the connectors are crazy expensive and don't work as well as a factory crimped connector.
Even if you don't buy the whole harness, you can buy a used connector with enough wire on it that you can solder/wire nut it in.
