2003 SC430 Navigation door issue
Hi everyone,
My navigation stopped working out of the blue and I want to try to fix it. The door does not open or close when I press the buttons but the screen turns off and on which is really strange. All buttons but tilt and open/close work. The door can be opened and closed using my hand (not too much pressure required) so I know its in the track. I have checked the fuses on the passenger side fuse box with no luck. Tilt also does not work.
Any help would be appreciated. I looked on previous posts but seems like most people's issues are off track/fuse. Although mine might be fuse, all the ones Ive tested seem to be working, any help on to check what specific fuse is also appreciated.
Thanks,
Thanks,
When you press the "open" button, do you hear any noises like a motor attempting to run? If not, there could be a connection problem with the motor. If you do hear noises, then maybe the belt came off its track or broke. (I think that the door is belt driven, though I may be mistaken.)
I do not hear a noise when pressing open and close button, just my screen turning off and on. How would I check connections with the motor? should I open it and see if the motor functions independently? Also my tilt does not work either. Could both motors be bad? a fuse does sound logical but I cant find one that doesnt work for some reason.
Thanks
Yeah, I'd make sure that the proper fuses are still good first. The connections to the motors will be behind the assembly and would require removal of the assembly to get to them. However the fact that neither motor works or makes a noise points back to a power problem, which is likely to be a fuse unless both motors are powered through a single connector. It is also possible that the board that turns the motors on is having problems but I'd look into the other items first.
BTW, welcome to the forum.
Ill open the unit this weekend and see what I can find out. Thanks! Its so frustrating
Check out pg 335 in the manual for a possible fuse.
http://drivers.lexus.com/t3Portal/do...f/OM24449U.pdf
nomods4me (01-08-19)
nkx1
01-26-16 12:02 PM
08pebbch
06-29-15 06:34 PM
