Feedback Needed For Potential New Product: 02-09 SC430 Climate Control LCDs
#151
Sponsor
![](https://www.clublexus.com/forums/images/ranks/rank-vendor2.gif)
Yes, it literally takes 30-60 seconds. Remove the old lens, stick our new lens in its place.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
![](https://www.clublexus.com/forums/signaturepics/sigpic178522_1.gif)
262-456-4147
#153
Sponsor
__________________
262-456-4147
262-456-4147
#154
Do you have or could you provide a video of this process to show us how easy it really is? Thank you.
#155
Sponsor
__________________
262-456-4147
262-456-4147
#156
Great vid. thanks. The vid stops at removal. I assume that you would clean up the unit from glue left behind with some adhesive remover or rubbing alcohol?
Also, why is the screen so expensive? It looks like the LCD panel replacement is only $10 more.Am i missing something?
Oldsig (08-28-19)
#157
Sponsor
The alternative is a $340 front panel from Lexus.
There is no other solution unless you want to cut a piece of thin plastic out from the hardware store.
We spent quite a bit of time, money and resources in developing and making the screen with the anti-glare coating and buying a significant quantity up front (in the thousands) so our manufacturer would even consider producing it so the price is what it is. If someone wants to figure out how to make one and sell it for cheaper then by all means go for it.
__________________
262-456-4147
262-456-4147
#158
I am very pleased with the Tanin replacement cluster on my '02.
It is much brighter than the old one, is accurate within the limits of measurement compared to the old one which was probably sketchy anyway, and is a visual improvement for daylight and nighttime driving. Moreover it allowed me to pass the smog test - the check engine light was out on the original cluster which is a failure condition. It was easy to install.
I just wonder if the old one I sent in was FUBeyondRepair?
TaninAuto (11-01-19)
#159
Sponsor
Please send us a PM with your first and last name, so we can look up your order details and find notes on your original cluster for you
__________________
262-456-4147
262-456-4147
ShawnOk (10-30-19)
bobster99
07-11-22 07:52 PM
TaninAuto
01-16-18 05:23 AM
