Door pops when opening
Old 01-27-18 | 09:19 AM
LEXZILLA's Avatar
LEXZILLA
Default Door pops when opening
I have a 03 sc430 and the doors pop when opening
its the little bar that comes out the inside of the door and is bolted to the inside of the door frame....
what is that part called or can you give me a part number
thanks in advance
Old 01-27-18 | 09:48 AM
VVTiBob's Avatar
VVTiBob
Striker plate: 69410-51010
Old 01-27-18 | 12:47 PM
LEXZILLA's Avatar
LEXZILLA
I'm sorry but it's the little metal bar that comes out of the front of the door
Old 01-27-18 | 12:51 PM
Coleroad's Avatar
Coleroad
There was a thread last summer. Someone on here bought a new one and installed it. For the same reason you are talking about. Wish I could remember who it was.
Old 01-27-18 | 12:53 PM
Coleroad's Avatar
Coleroad
Old 01-27-18 | 01:36 PM
Hyper15125's Avatar
Hyper15125
I have same issue with only 32k, loud pop when opening driver door.
Old 01-30-18 | 10:29 AM
VVTiBob's Avatar
VVTiBob
The popping sound you hear opening the door is a worn tension pin on the body frame side. A $5 part in the LS (new part), but in the SC you have to replace the entire door check assembly, about $100 . Doubt a salvaged part would be any better. A good test is to compare driver’s to the passenger’s door for the noise. If you do proceed with the replacement, make note of the assembly’s orientation before removing it from the door panel.
Old 01-30-18 | 10:59 AM
Hyper15125's Avatar
Hyper15125
yup, i just ordered a new one, 116 bucks
Dasanii19
GX - 1st Gen (2003-2009)
08-07-18 03:20 PM
cbrkat28
05-20-18 05:06 PM
GTR20
03-05-18 04:03 PM
IRCRomeo
08-18-07 05:27 PM
TRiis2004
SC- 1st Gen (1992-2000)
03-03-02 01:27 AM
Quick Reply: Door pops when opening
