Seat problems
Old 02-05-18, 11:39 AM
myLexRX
myLexRX's Avatar
Default Seat problems
Hello All,
Recently noticed two issues with the driver seat (honestly did not check the passenger seat). The lumbar support and seat heater don't work. As I turn the seat heater dial, the light turns on but the seat does not warm up. I press the lumbar support button and nothing happens.
Can both of these problems be related? Perhaps a bad fuse? The car is an '07.
Any help would be greatly appreciated.
Old 02-05-18, 02:58 PM
mrblister
mrblister's Avatar
Originally Posted by myLexRX
Hello All,
First place to start is check your fuses
Old 02-06-18, 06:44 AM
JohnnyCake
JohnnyCake's Avatar
What Mister Blister said.
Did both of these failures occur simultaneously?
A break in the seat heater grid is unfortunately pretty common and virtually un-repairable except at high cost and huge effort. Also, it will look bad unless you do both seats.
Old 02-06-18, 06:52 AM
mrblister
mrblister's Avatar
I had seat heater bottom go bad on my 2004 gx470 I had bought with extended warranty through lexus they fixed it under warranty ; It was the drivers side. Then had to remove the seat and and put in a new grid & bunch of new clips hog hooks etc the total they billed Lexus for the warranty was 1013.32 . It was done with out a issue and it looked as good as the passenger side.
Old 02-06-18, 08:49 AM
DshngDaryl
DshngDaryl's Avatar
There are three connectors under your seat. You may want to look under there and make sure they are all connected
Old 02-06-18, 09:56 PM
JohnnyCake
JohnnyCake's Avatar
When I got a quote for the SC, I think it was closer to $2K, but that may have been because they wanted to replace the whole seat. In that scenario (one new, one a decade old), its going to look like crap. You were lucky they were able to repair and you didn't pay a penny.
Old 02-09-18, 07:06 PM
OBP
OBP's Avatar
$2K is about right. Driver seat heater issue. Dealer replaced seat and seat back and only left headrest unchanged. Done under Lexus Platinum extended warranty. The colors matched up pretty good and mine is a 2005 with ecru. I think that fix got done in 2011 or 2012. My leather is generally in good condition even now, on both sides
Old 02-20-18, 06:33 PM
rpjense
rpjense's Avatar
You could go aftermarket a lot cheaper than $2k. And you'd have the same result.
lynhnn
RX - 3rd Gen (2010-2015)
11-19-13 03:50 PM
UnSub
10-10-11 05:57 AM
PAVGR
01-08-11 02:19 PM
Integrator
01-21-03 12:35 AM
Quick Reply: Seat problems
