Bumper repair/replacement
Hi all,
Hello, you have been so helpful in my previous questions, figured give it another shot.
So a few years ago i got in a fender bender and the front bumper had to be replaced. I cheaped out and got a cheap aftermarket bumper. after about a year the top of the bumper by the tire, where it fits in the fender slot, started cracking and ripping, it looks very ugly. Ive thought about gluing and reinforcing it from the inside with some fiber glass but not sure if its possible as 1) its load bearing and 2)cant get thicker as it has to fit in the fender slot. A "professional" told me, it can be done from the outside but will likely fall apart since its load bearing.
Anyone has any experience with repairing this area? Or do you know a good quality aftermarket bumper brand? Im not trying to spend $500+ at the dealer and junkyards have not been working out so far.
Thanks in advance
oh its a 03 btw
Thanks in advance
oh its a 03 btw
I would take it for a second opinion. I think a good bodyman could be able to put a couple of rivets into your current bumper and have it work. it would be cheaper than replacing the whole cover.
The could also probably use the inner fender well as an additional support to hold it into place
What do you mean rivets? wouldnt that show on the outside of the bumper? we've been trying to bend a sheet of metal to a hinge and glue it with waterproof epoxy but theres lots of 3D bends in the bumper so it creates creases in the sheet when trying to bend. Any suggestion could be tried
I have never taken apart my bumper, but I assume there is a way the bumper cover attaches to the fender. Most likely with bolts, but possibly with plastic clips.
If my assumption is right, the bumper cover and the fender must have flat edges that meet each other. That is where I would see if they could put the rivets, or reinforce the bumper cover with a piece of metal to spread out the weight load.
GregoryNP
08-29-17 12:04 PM
