Pioneer Radio Installation 2007 SC430
#46
WSVC206, that looks similar to work done by Musical Indulgence here in Maple Valley. Install looks clean and professional. Nice work! Can you recommend an installer in King County to install an Apple Carplay system in our 2006?
Rich
Rich
#47
@Bgw70
I received my pioneer avh-W4400NEX and beatsonic today and will attempt the install.
i have everything unpacked and have a few basic questions
1. Pioneer AV input has various connectors. I do not see a label for “front left” and “front right” to connect to beat sonic just “front output”, “audio input”, “subwoofer input” as well as rear and other ancillary cables.
2. How exactly do you connect beatsonic L/R speaker connectors to the new head unit since they are different connector types. Are you just supposed to Insert the smaller beatsonic connectors into the red/white AV inputs?
3. Where exactly do you input the red yellow orange blue accessory wires for antenna backlight etc?
4. Do I need to solder any wires here or is this supposed to be plug and play?
#48
@Bgw70
i didn’t solder any wires.
#49
i looked but found no adapter for the small antenna plug on the windsheild...let me know if you find one.
i used a splitter for the video. Note post 11, I split the camera, one to the upper screen and one to the radio. The radio video output also went to the upper screen sharing a splitter.
Does that make sense?
1. I understand using the splitter for the dual video from the backup camera but I'm not clear how you have two different pictures on the radio/nav screens. My objective is to have the backup video on the upper screen while the lower screen displays the radio functions.
2. Was it necessary to remove the rear seat side panels? I'll admit, I would like to check on those speakers. I replaced the foam on the sub and 6X9's but the 4's sound okay.
#50
I solely use the windshield antenna. I had an old GM antenna adapter on hand from a car I had many years ago that I put an aftermarket head unit it, it works perfect, same size.
#51
chassis 5700 vs 2330
The radio was finally installed and I must say, I forgot how much work was involved...LoL.
I really like this Pioneer AVH-2330NEX. Better than the AVH-X5700BHS.
I have the 5700 that I am happy with. Why do you prefer the 2330? If its a better performer, I might have to upgrade.
Bag everything from each area and it will make it easier during reassembly.
I removed this part but it wasn’t required.
#52
model number
Both units worked flawlessly, happy with both.
#54
#55
i like the AVH-X5700BHS but prefer the AVH-2330NEX because it has Apple Car Play. When I purchased the AVH-X5700BHS, I don’t think I knew about Apple Car Play.
neither has GPS but both allow me to use transfer the WAZE GPS app to the radio screen.
#56
Can I jump in here? I am about to do the very same install in my 2003. Two questions...
the upper screen can display, OEM Nav, backup camera or a movie from the radio...all while you are using the radio normally.
i hope that answers your question.
2. I don’t think I needed to remove the rear side panels, I probably removed too many items to do the install.
nothing is difficult to remove.
here is another thread on what you can display on the upper NAV screen...this is my 2002 SC430
https://www.clublexus.com/forums/sc4...with-pics.html
#57
thanks
that is a very NICE high end unit!
#58
it let’s your passenger access all functions of the radio while the vehicle is in motion...like watching a movie.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
we need one for the NAVIGATION in our cars LoL
msteele (09-06-20)
#59
If using a lot navigation through Android Auto, Apple Carplay, or built-in it's definitely better to have it on the upper screen. Or your phone mounted at that same eye level. The head unit is so low it's not good to take your eyes so low while driving That much exra time you are not looking at whats going on in front of you.
#60
the micro bypass is for the Pioneer radio. It makes the radio think you are stopped and then will allow a movie to be played anytime.
