Red or BLUE coolant for SC430?
I needed to buy some top up coolant for my SC430, plus a new radiator cap, and looked up the service manual for what to buy. My recently Lexus serviced car currently has RED coolant in it. To my horror, the manual says to use BLUE silicate and borate free coolant specifically for Japanese cars NOT the red kind !!!! The IS350 manual is less descriptive in its coolant requirements.
Blue Long Life Premix Coolant is Silicate, Borate and Phosphate free. Japanese vehicles require Silicate and Borate free coolant, while European vehicles require Phosphates free coolant. Safe for use in Japanese vehicles as it DOES NOT contain Silicate or Borate
Nulon RED Long Life Pre-Mix Coolant is a pre-diluted, 50/50 mix of Nulon Red Concentrated Long Life Coolant (RLL) and demineralised water.
Any thoughts on BLUE or RED coolant???
Does my car need an urgent life (radiator) saving transfusion of BLUE?
Yeah, but the Australian SC430 service book says, on page 416, to use non-amine, non-nitrate, non-borate ethylene glycol based coolant. This description equals the Nulon blue product. The RED product does not have these properties. Hence my question. It may be a storm in a teacup but I thought I would ask the collective wisdom of the SC430 clan
I'm not familiar with any coolant for Toyotas being blue, just pink/red. Then again, I'm not that up on antifreeze either, especially in non-US areas. Maybe you could call your dealer's service adviser, they are usually fairly helpful?
From an '06 US/Canada manual:
“Toyota Super Long Life Coolant” or similar high quality ethylene glycol based non-silicate, non-amine, non-nitrate and non-borate coolant with long-life hybrid organic acid technology. “Toyota Super Long Life Coolant” is pre-mixed with 50% coolant and 50% de-ionized water (for the U.S.A.) or 55% coolant and 45% de-ionized water (for Canada).
Similar to Harold I'm not up on antifreeze in non-US areas. Lastly, when my timing belt/water pump was changed the mechanic replaced my radiator cap with a new non OEM cap and it leaked so I replaced it with an OEM cap and no leaks. Maybe it was fluke, but I would get an OEM radiator cap.
Natroth (05-28-18)
This appears to be a good alternative stating it meets three of the Toyota antifreeze standards. WalMart sells it for $12 gal here in the US.
https://www.walmart.com/ip/Valvoline...allon/49660461
OEM all the way
Similar to Harold I'm not up on antifreeze in non-US areas. Lastly, when my water pump was changed the mechanic replaced my radiator cap with a new non OEM cap and it leaked so I replaced it with an OEM cap and no leaks. Maybe it was fluke, but I would get an OEM radiator cap.
Gotta love the packaging & marketing ploys by vendors versus functionality of the product. Remember coolant starts out clear and manufacturers add dyes for a number of reasons some useful, others not so much.
Might I suggest some lite reading on what they are up to: http://www.autoserviceprofessional.c...r-makers-up-to
Rule of thumb: Don't change coolant color from original spec.
GmanSC (05-29-18)
