Lexus 430 SC hard top convrtible. The top not working
Unfortunately the Convertible top system doesn't store any errors. It does a self check each time you push the button, so disconnecting the battery won't really work.
When you drive around, the vibrations jiggle the motor, which I believe spins the Bendix in the motor a little, making the top work
Okay! I got the trunk open. I closed it. And now when I try to close the top it starts to close .... about 6" and then goes back down. It does not fully go back down in to the open position until I use the open button then it goes to fully open. And there is no beep when trying to drive it. Now that I have access to the trunk what should I check?
Out of curiosity, what part of AZ are you in? Prescott?
I live just over the hill from Prescott. In Cottonwood.
I don't have Techstream or a diagnostic computer. My mechanic does not run techstream. He uses a more generic scanner system. The only codes he could pull up were emission related. He is going to put me in touch with a mechanic at the Toyota dealership in Prescott.
