roof don't close
Repaired problem !!
There was a piece of tapecase ruban squeak reduction (3M) sutck in the left amount (pilar in english, I think...).
I was able to remove it with tweezers !!!
I put this tape to reduce the noise on the rods that lock the roof.
BAD IDEA !!!
Thank you so much for your help and assistance
BAD IDEA !!!
What are the odds that two unrelated members used the same method to “quiet” the closing sounds of the roof and BOTH led to roof systems failures? I suspect the odds are astronomical.
That's right !! Moreover, I found this solution "anti noise" on this forum and I also saw that it had been a problem for a member of the forum. It was also a reflection in the search for the cause
