Important warning / notice: 100% brake system failure lexus sc430
Yeah it shouldn't happen even one time. I'm lucky to have survived because I didn't panic in the moment but I was scared ****less, for lack of a better word. I didn't jump it right into low gear until I passed a couple of others -- if I threw it into low right away at that speed, I think it would have been a mess -- tailspin or whatever. Low gear in that car can climb Mt. Everest
I wondered if more frequent brake fluid flush would help this issue.
This is the first time I heard of complete brake failure
But even 1 time is too many times to see this happen.
wow,, complete brake failure is not a good thing.
if you are driving 75Mph and your lowered the car to
A lower gear, that probably would damaged the transmission
but I guess that is better than totaling the car not to nebrion
a full blown accident.
Hope everything works out
you would be hard pressed to damage the transmission doing the semi manual shifting...BTW, I don’t believe the transmission would allow a shift to first gear going 70mph...most, if not all automatics have speed limiters...
Hey BgW70
I was just curious but the earlier SC 430 came with a 5 speed
did you take your older SC or your newer SC
when you went to 5th,I assume you must have taken youe
newer SC. By dropping from 6 to 5th gear on the newer SC,
You probably would be fine but if you were in the older SC
with 5 speed, moving at 80MPH and going to 4speed,
I think the drop will probably do serious damage at that high speed
To the gear box if you had to use the gears to eventudllyvstop
but again at that point, I don’t think it matters if it is life threatening
Even when you hit 40mph, with 4th speed, I don’t think
the car will come to a complete stop unless you drop it to 2nd
I am no expert but just my thought to the stop issue
Our SC equipped with S mode for manual driving and down- shifting. In the owner manual, there is the chart that indicates the max speed for down-shifting for each gear.
You won’t be able to downshift if your speed exceeds the allowable speed . I don’t think you can damage the trans.
Thanks MJN331...I am delighted that no one was harmed, How, I wonder, can you and others be CONVINCED that this issue will not happen again or with other SC430's. For example, does the Toyota Corporation understand what happened, and if so, have they taken steps tp correct this issue...how do we know the loss of braking ability is not systemic? Are there recorded cases of this loss of brakes occurring among the fleet? Have there been any fatalities? What is the root cause? Can we trust Lexus to repair? Do we have to go to an outside mechanic to assess the viability of the braking assembly. Has MJN's Lexus service Center reported this to HQ? Who is the government is interested in this rather quixotic issue. Finally, why should I not anticipate my SC experience the same unknown cause brake failure?
Yes I agree
If this is a documented case where a serious accident
could have occurred. Then as a SC owner, we should ask
Lexus if they are not willing to replace a potential failed
brake/ABS booster, they would be liable. I think
Something like this could be a class action lawsuit
To be honest
To be honest
Yes I agree
To be honest
To be honest
You have been a member here for 14 years. Have you ever heard of this happening before on an SC?
It seems like a very limited occurrence and not a widespread phenomenon.
I don't know if I agree. A part failed on a 16 yer old car. Though the ramifications could have been catastrophic, are they any worse than a car tire blowing out?
To be honest, this is the first time I heard of an SC with
100% brake failure while on the freeway. I guess the question
Is if there is 1 document case of a car with complete brake
failure where something serious could happen, is this enough
for the manufacturer look to see if a part is defective?
If the car shows to be fully serviced regularly , should a critical
part failed? Just because a car is 16 yrs old, does it mean it is ok
for a critical part to fail?
If there is 1 document case of a car with complete brake
I guess Lexus would make the argument that all brake boosters industry wide, work the same. And they include a hand brake on their cars for just this instance. Also they would probably question whether there was a complete brake failure, or just a non power assisted failure. The first car I had was a 76 Buick century. It did not have power brakes. You had to REALLY push down hard to stop. Did the booster failure block the mechanical linkage to the brakes, or was it just a matter of having to push the brake pedal harder than the user ever had to in the past?
signdetres (07-07-18)
All valid points made ...
Good points. Lexus did do a recall on their brake boosters a few years back, but it did not include the SC.
Yes I agree
To be honest
To be honest
