Techstream & Cable Problem and solutions
Old 01-31-19, 03:29 PM
  #136
GmanSC
GmanSC's Avatar
Dennis,
The cable just pull straight out. Seemed like your version 13 is corrupted or when you uninstalled the version 12, it left behind some files that is not compatible with ver 13. If you can not get the problem resolve from the vendor, install the version 12 and ignore the upgrade. Many of us here still using older version without any problem.
Old 01-31-19, 03:50 PM
  #137
Bgw70
Bgw70's Avatar
Here are some screen shots of my software...I think you were so close running version 12.
Old 01-31-19, 03:55 PM
  #138
Bgw70
Bgw70's Avatar
Old 01-31-19, 03:57 PM
  #139
Bgw70
Bgw70's Avatar
Forget about version 13 and just use version 12...
Old 01-31-19, 04:10 PM
  #140
Bgw70
Bgw70's Avatar
Copy and paste this key in your version 12 software.
1111111111111111111111111111111150001703161820
Old 01-31-19, 06:50 PM
  #141
DJWLDW
DJWLDW's Avatar
Bgw70
That is one of the 2 keys that I have. Am uninstalling 13 now and will reinstall the oldest 12 next.
Dennis
Old 01-31-19, 07:54 PM
  #142
DJWLDW
DJWLDW's Avatar
Bgw70
In that last picture you show a current key on the page for registering Techstream software and then the blank space.
On mine I do no show any current key on the line above the blank space. It just says current key and there is nothing there?
At some point I had a green light on the Mini VCI cable but as soon as I plugged into the usb on the laptop it is now red?
I reinstalled the oldest 12 which is 12.00.127 it all looked good no error messages, no missing dll's or missing files. I can click on the setup and configure I can click on the TIS box and change things. But as soon as I hook up to the SC and turn on the key it takes me to that register software page which has no current key listed and if I type in one of the 2 keys I have it takes me to the TIS web wanting all kinds of info.
Dennis
Old 01-31-19, 10:31 PM
  #143
GmanSC
GmanSC's Avatar
Dennis, if you can get to the main page (the one with the car illustration ), your installation is done. You don’t have to do the registration. Just connect cable to the car, turn ignition to ON, hit “connect to vehicle,” what do you have? If you don’t get the message “unable connect to VIM”, you’re good to go.
Old 02-01-19, 12:32 AM
  #144
Bgw70
Bgw70's Avatar
Originally Posted by DJWLDW
Bgw70
Dennis
If this page pops up in the picture below, do the following.
NOTE: the Software Registration, on left in the Green Box, will take you to this page.
NOTE: don’t worry if the current key is blank.
Type in the current key, click OK.
NOTE: You should see an expiration or days left, see Green box lower left side.
NOTE: Do NOT click Software Registration, Red Box, it will take you to their web page.
Old 02-01-19, 08:53 AM
  #145
DJWLDW
DJWLDW's Avatar
Bgw70
1: No expiration date on lower left
2: I fill in the key click ok it goes away for a second or 2 and the same page comes back with the space empty?
3: When I hit connect to the vehicle that page comes up
4 When I first plug in the cable into the laptop the light is green. As soon as I open Techstream the light in the cable goes red?
GmanSC
I am at the main page screen the one with the car illustration but as soon as I try to connect to vehicle I get the register software window.
It's like the key.exe file is not taking when I drag it over the techstream icon on the desktop and drop on the file. I am assuming that is what it is asking for when in the instructions it says to move the key.exe file into the techstream folder?
Dennis
Old 02-01-19, 09:07 AM
  #146
DJWLDW
DJWLDW's Avatar
I have 3 icons on the desktop
1.MVCI firmware update tool. When I open it a screen with Xhorse firmware update tool 2.0.1 for mini VCI across the top and then a page with a bunch of blanks: Device SN, Model, Firmware, Dealer, Status All blank. I just hit the Device icon button and they all filled in. It is showing the cable connected. Do I need to do anything else with the other icons on that page? The firmware version is showing 1.4.1. The seller show it to be version 2.0.4?
2: The Techstream Icon (a blue small letter t)
3: TSE file folder. In this folder is 2 additional folders: 1 Default_User and when you open there is nothing in it. 2. Techstream file backup folder which contains a notebook read me text Document about what will be saved there.
Dennis
Old 02-01-19, 10:14 AM
  #147
Bgw70
Bgw70's Avatar
Does the firmware update tool look like this when filled in?
Old 02-01-19, 10:20 AM
  #148
Bgw70
Bgw70's Avatar
Dennis,
I am running this version 12 and it works just fine.
create a new folder on your desktop and download the files at this link...
https://drive.google.com/drive/mobil...3M?usp=sharing
Old 02-01-19, 10:49 AM
  #149
GmanSC
GmanSC's Avatar
Dennis,
I see your problem.
1. If you have a keys.exe file, you need to run this file (execute it) before run Techstream file. It will put the key to the registry, so when you run the Techstream, it knows you have a key.
2. If you have a key.txt file, you need to open the file, copy the key, run Techstream and paste the key to the window.
Old 02-01-19, 12:34 PM
  #150
DJWLDW
DJWLDW's Avatar
Bgw70
Yes that is what it looks like filled in.
Dennis
