Techstream & Cable Problem and solutions
#226
Regardless of cable ver., your TechStream will not connect to the VIM if you installed with Win10 due to the MVCI driver. Sorry but you need a pro help or just install it to a Win XP. BTW, the newer version of cable firmware and TechStream software just for newer Toyota & Lexus models.
#227
Greetings New Member Here,
Trying to using techstream and cannot use the disc ordered. I was wondering if anyone had firmware 2.0.1 to download? I tried looking online and found a virus on one of the share sites.
If anyone is in the SGV area or 91754 and can help out with turning off the DRL, that would help me out a lot. Or, can let me know where to find the firmware for 2.0.1 so I can try to connect to car. The DFEH in California is not very helpful for me.
Thank you and have a good day!!
#228
#229
#230
Thanks for the quick reply.
And my apologies for not being more clear, its not the firmware I need it is the driver for the computer to connect usb side.
I did look at the ad from the seller and the Mini VCI I ordered said 2535 Firmware 2.0.4 but, 2534 arrived with 2.0.1 and I still need the driver if I can hook up this cable.
Can this cable and techstream 12 work together to connect properly? Thanks again in advance for any help.................
#231
#232
Your problem is MOST LIKELY that you are trying to use 32 bit drivers on a 64 Bit Computer. Most versions of windows 10 are 64 bit. Techstream and the cables were designed back in the Windows XP days. Your best bet is to buy an old XP laptop off the internet and use that. Otherwise you need to google "Techstream 64 bit" or get a 32 bit version of Windows 10 from the microsoft website and wipe out your computer and start new.
#233
Thanks for the heads up been searching why my brand new ebay generic techstream can't customize my 08 ls460
Do you think its cause of the cable version?
I took a pic of the "VIM" connection page and it's missing one or two things. What do I need to buy?
#234
What's exact problem? Could you connect to VIM?
#237
Techstream on an old unconnected XP laptop
I just got my Techstream V13.00.22 and am installing it on an old Toshiba laptop running 32bit XP.
The issue is that this laptop has not been connected to the internet in years.
Not really a Techstream question yet, but what risk do I run connecting a non-updated XP laptop to the internet long enough to download the required files for Techstream installation?
Thanks,
Jonas
Thanks,
Jonas
#238
Download the install file from a modern machine. Then transfer them on a USB stick to your XP laptop. Just never activate the XP network connection .... ever.
Just decline to install the extra stuff when asked.
#239
Don't go to sites that your mother would not approve of and you run almost zero risks. I found that I had to load Fire Fox to get on the web because the IE would not log onto the forum any longer to get to the link to download. I loaded CCleaner and that was it. No issues
Dennis
Dennis
#240
My biggest beef with Techstream is always having to do the VSC reset procedure after using the cable.
Useful software, but have your VSC reset tool ready after every usage episode.
Formerly employed a paper clip, but like others, now use a dedicated reset tool made from an OBD connector. That avoids the wrong pins connected ooops.
Techstream is still needed for advanced settings and data, but for simply scanning for trouble codes, I'm simply doing it via bluetooth LeLink adapter and Torque Pro.
No VSC reset problems when doing it that way.
