Techstream & Cable Problem and solutions
Old 01-15-19, 12:16 PM
  #106
GmanSC
GmanSC's Avatar
Thanks mnew. Now I know what system check is. I’ve saved it for future reference. My question now is how do I turn the TPMS back on? But that’s for few years down the road, when I get rid of the run flats, I’ll deal with it then. BTW, what is DTS?
Old 01-15-19, 12:31 PM
  #107
mnewxcv
mnewxcv's Avatar
I would think rerunning the signal check and completing the process would enable TPMS again. DTC = diagnostic trouble code.
Old 01-19-19, 10:20 AM
  #108
DJWLDW
DJWLDW's Avatar
Am I correct in thinking if techstream will run on an XP machine it will also run on a Vista machine as well?
Dennis
Old 01-19-19, 12:47 PM
  #109
Harold57
Harold57's Avatar
Dennis, I imagine that with the right IT guy, a Vista machine can be made to work. BGW & I put a lot of time in trying to get my Vista based laptop to work and I finally gave up. I'm guessing that it also needs the registry adjustments. OTOH, my Vista laptop is also a 64 bit machine, so it may have 2 strikes against it. But if you figure out how to do it, let us know!
Old 01-19-19, 12:56 PM
  #110
DJWLDW
DJWLDW's Avatar
Harold 57
I am going to try and put it on my Dell Inspiron Mini which has XP on but my brother gave me a nice old Dell with Vista on it. So it will not load as easy on a Vista machine as it will on a XP machine? Is that correct?
Dennis
Old 01-19-19, 01:04 PM
  #111
iolmaster
iolmaster's Avatar
Originally Posted by DJWLDW
Harold 57
Dennis
It has less to do with the operating system more to do with 32 bit vs. 64 bit. I put it on a Windows 7 32 bit with no problems. It is what I currently use. If the Vista is 32 bit I am guessing you will have no problem.
Harold57 (01-20-19)
Old 01-19-19, 06:25 PM
  #112
GmanSC
GmanSC's Avatar
Iolmaster was right. The installation of Techstream depends on the 32 or 64 bit system. If you have older version, it will only install on the 32-bit, Window XP, Vista or Window 7. If you have a newer version, it will install on 64-bit machine with 64-bit Window 7, 8 or 10.
You might have problem with connect to VCM on both instances but that is another problem. By the way, what is OTOH? I must learn these acronyms.
Old 01-20-19, 04:45 AM
  #113
iolmaster
iolmaster's Avatar
On The Other Hand!!
GmanSC (01-20-19)
Old 01-20-19, 02:31 PM
  #114
Harold57
Harold57's Avatar
Do you know at what version the software will install on a 64 bit machine?
Also, is there a way to download a later version of the software or do I need to buy a new one to accomplish that?
Okay, my turn, what is VCM?
Old 01-20-19, 04:58 PM
  #115
iolmaster
iolmaster's Avatar
Guys, once again it is not the version of TechStream that is the issue with 32 bit vs 64 bit. It is the driver for the cable.
Old 01-20-19, 05:05 PM
  #116
GmanSC
GmanSC's Avatar
Sorry it should be VIM. Don't know what it stands for, probably Vehicle Identification Module?
Here is the link to ver 10 Techstream with driver.
https://megaupload.nz/Q4Jf45k1bb/MINI_VCI_ISO
It is a disc image file and you will need software to 'mount' it so windows thinks it is a cd rom. I recommend WinCDemu, which is extremely easy to install and use.
Harold57 (01-20-19)
Old 01-20-19, 05:59 PM
  #117
Harold57
Harold57's Avatar
Thanks for that clarification iolmaster. However, I couldn't load Techstream on my 64 bit Vista laptop. I could load it on my 32 bit XP laptop.
Thanks for the link GmanSC. I may try that if I can get my nerve up for it and find the time to take it on.
Old 01-20-19, 10:38 PM
  #118
GmanSC
GmanSC's Avatar
Originally Posted by mnewxcv
I reverted back to 12.20.024 because I was having a problem with v13. When clicking data list for TPMS, it would crash the program. All fine back in v12.
Mnew, my ver13 crashed when I clicked on data list. It also crashed when I do the heath check. It ran to ECỤ 25 then crashed.
Can you upload version 12 on Megaupload?
Old 01-21-19, 11:50 AM
  #119
mnewxcv
mnewxcv's Avatar
sure, I can do it tonight when I get home.
Old 01-21-19, 04:15 PM
  #120
mnewxcv
mnewxcv's Avatar
here is the ISO file for techstream 12.20.024. I make no claim that I own this file(s), but this is the version I was provided by the ebay seller I purchased my cable from.
https://megaupload.nz/035cpbr4b1/toyota_12.20.024_iso
If you are installing this over another version of techstream, I highly suggest uninstalling all of the old techstream software before trying to install this version.
