rear view mirror Replacement
Plug in the mirror.? Do not understand what you want to do.
If you are referring to the cable that comes out of the rear view mirror when it is loose, the connector is on the driver's side of the hole in the headliner. Just match shapes and plug it in.
Welcome to the forum.
Is it as easy as opening the light assembly to access the plug? I see in this picture there is a spot for the mirror cable to go through the headliner and end up right under the lights.
Is that where you plug it in?
By the weigh Leigh, welcome to Club Lexus, which part of Arizona are you in?
Is that what you need?
swaangin
02-26-20 12:19 PM
