Serpentine belt
Old 08-23-18, 09:18 PM
BRK
BRK's Avatar
Default Serpentine belt
My 2008 SC 430 only has 15.000 miles on it.
Should I replace the Serpentine belt.
I’m not having any issues.
Old 08-24-18, 08:51 AM
Bgw70
Bgw70's Avatar
Welcome to Club Lexus!
you should be concerned about the timing belt, water pump, tensioner, idler pulley etc...and have them replace the serpentine belt since they removed it to do the TB job.
you can always ask your local Lexus or Toyota dealer.
Read this...
https://www.greggsauto.net/2013/07/t...-timing-belts/
BRK (08-24-18)
Old 08-24-18, 02:17 PM
BRK
BRK's Avatar
Why would a timing belt need to be replaced on a SC 430 with only 15,000 miles
Old 08-24-18, 02:38 PM
RXGS
RXGS's Avatar
Technically because of age and the rubber degrading over time, but with a 2008 and that low of mileage, I wouldn't worry about it for at least a few more years.
BRK (08-24-18)
Old 08-24-18, 05:37 PM
Coleroad
Coleroad's Avatar
Think about it like this. Would you trust 10 year old tires on your car, even if the had low miles? Now a 10 year old rubber belt, that if it breaks you are buying a new engine. Rubber degrades not just from use, but time also.
Old 08-24-18, 06:04 PM
RXGS
RXGS's Avatar
Difference is tires are not designed to last this long, belts, to some extent, are.
Old 08-24-18, 07:01 PM
Prasha
Prasha's Avatar
Inspect the belt under the hood, see it touch it and feel it then ask yourself should you? or ask any mechanic. I have 2002, with 64k miles, original belt.
BRK (08-25-18)
Old 08-24-18, 07:08 PM
Pep59
Pep59's Avatar
Has anyone ever known or heard of someone whose timing belt on an SC430 or other Toyota 4.3L actually broke?
It would be interesting to know the age/mileage of a real life timing belt failure example.
I believe the rubber is a synthetic rubber and I would like to think the Toyota engineers built in a margin of safety over and above the recommended service interval.
There are probably many factors such as driving style, weather fluctuations, etc. that would influence the life cycle of a belt.
And I totally agree that its a good investment rather than trying to rebuild or replace your engine (I did mine at 72k miles/ 13 years and it looked just fine).
The serpentine belt is very easy to visually inspect for cracks and missing teeth.
I'm not even sure how you would easily remove a cam cover to see the timing belt and cycle it so it could be inspected?
Last edited by Pep59; 08-24-18 at 07:12 PM. Reason: mix up between timing and serpentine belts
Old 08-24-18, 11:14 PM
GmanSC
GmanSC's Avatar
Yes, plenty of talk about that. Read post #15.
https://www.clublexus.com/forums/sc4...ming-belt.html
I just done mine at 65k miles of an 07 for less than $750 that included transmission fluid serviced and Mobil 1 oil changed. Post # 13 and 16.
https://www.clublexus.com/forums/sc4...f-price-2.html
Pep59 (09-03-18)
Old 08-25-18, 09:07 AM
Bgw70
Bgw70's Avatar
what did you think of the article about timing belt life?
the link is in my previous post.
just curious, you asked about changing the serpentine belt, is there any difference between that belt and the timing belt?
Coleroad (08-25-18)
Old 08-25-18, 09:55 AM
Prasha
Prasha's Avatar
I find that is a strange post and thread, a minimum of $25K to repair the damage (which is more than the car is probably worth).
There is no update about what he finally did....
Any one else reported? who broke the SC430 engine because of the timing belt?
Old 08-25-18, 02:14 PM
GmanSC
GmanSC's Avatar
Our Lexus has TB and SB. TB is larger with teeth, SB is smaller no teeth. SB is visible from front view.
Old 08-25-18, 02:28 PM
Bgw70
Bgw70's Avatar
thanks Gman...I was just trying to figure out what the OP was thinking when it comes to belts...
6SC430PB
02-05-16 05:01 PM
GregoryNP
04-15-14 04:50 PM
Sneeper69
04-23-13 04:43 PM
BT3100
10-05-10 09:48 PM
hotttoddie
Performance & Maintenance
09-04-07 07:23 PM
Quick Reply: Serpentine belt
