how to remove/reinstall ML amplifer
I don't see anyone ever having put up a step by step on replacing the ML sc430 amp-I have a 2002 which sometimes BLARES at full vol., a known defect and TSB replacment is the fix from 2003 on!
There's nothing on Youtube either. My parts guy at LEX. Northboro says itss a bunch of panels and very easy once you get at amp to pull it. IS this so? What tools do I need and how to not break conenctors/clips etc? There was one seller who says you need to recalibrate nav and other fun stuff since this is "complicated sensitive equipment"...really?
Ok, if it's so easy, would you pls. send me the specialized toolls needed to remove the TOY/LEX various bolts, clips and snap ons which keep panels and amp in place? Please also find time machine back to 2002 to determine all #'s for putting proper replacement ML/Lexus replacement amp in without it blaring/dying, as well any calibration equipment or instructions needed for the integrated NAV/audio.
OH, you don't have time to send me obscure parts and service....just take pictures, as you obviously don't know a 2002 SC430 any better or any worse than an average Lexus dealer!
Have you tried the search feature?
i remember a detailed set of instructions to remove the trunk panels and the amp.
Using google, search, “SC430 amplifier” there are plenty on eBay with part numbers.
You are probably correct, a Lexus dealer knows these cars much better than anyone on this website. But if you go there, bring $$$$, we are free.
The truth of the matter . The sc430 is like a lego toy. The panels and parts are very intuitive to remove. Basic trim tool plastic available any auto parts store . Then just pry up the button like clips remove the spare tire well and each panel comes out starting with the bottom and moving onto the rear . There are a few bolts but the are obvious once you start to look at it. The amplifier is under the panel on the left side of the trunk from 2002 up to last year the panels all remove the same. Just have a little patients and be kind to the people trying to help you.
I will be taking mine out to replace the tiny fan inside the amp, the one inside is making noise now and I've read in a thread that a replacement amp is about $500. The tiny fan is only $8.
wish me luck.
Autoplak
02-20-23 06:21 AM
firebird37
12-30-19 04:50 PM
