Retractable roof failure
Hi
Can anyone tell me if you replace the roof control ECU , is it a plug and play or does the unit have to be coded to the car , i have been told by Lexus specialists it is plug and play , but the Lexus main dealer says it must be coded to the car before it will work !!!!!!!
Thank you
Thank you
I would GUESS that it does not need to be coded, since it does not control any anti-theft accessories.
In case you need it, it is part number
8972024010 for years 2002-2008
Why do you think you need a new roof ECU? What kind of error code are you getting?Last edited by DshngDaryl; 10-29-18 at 02:00 PM.
the dealer says it was an ecu and that it needs coding to the car , the specialist says it dosnt , new 1500 dollars , second hand 200 dollars
