Are jis screws common knowledge? I thought it was. What leads me to asking is prompted by a call from my nephew yesterday. He was having trouble with a rotor screw. I asked him if he was using a Phillips head or a jis screwdriver. To my surprise he had no idea there was such a thing as jis. ( he's only 18) I wasn`t surprised he didn`t have a jis screwdriver of his own, but I thought he knew about them. Japanese cars for years haven`t had Phillips head screws in them. They`ve all been jis. Even U.S. auto manufacturers use them anymore. Using a Phillips head screwdriver in a jis head screw makes for a great chance of stripping the screw out.
I have heard of a JIS screwdriver. The USAF taught me the proper tool names many moons ago. No one ever mentioned JIS...I had to google it.
here is a nice picture of the difference.
i have always called them number 0, 1, 2, 3 Phillips screwdriver.
The Phillips head never sits right in a jis. Plus they cam out of a jis head really easy. so you have to apply a lot of inward force To keep if from doing so. When trying to use a Phillips head in a jis you end up using a size to big because the tip will hit the bottom before it's completely seated with the right size.
Vessel is the brand jis screwdrivers i prefer . They are just nice quality. I have a set of hozan, but they aren't very good.
Most people and companies outside of Japan have absolutely no idea what they are. With the similarity in appearance to the Frearson and the Phillips the screws are often damaged in removing and installing with the wrong tools. JIS tends not to camout like Philips. The JIS driver can be used on Phillips quite easily but not reciprically. Drivers are not easily available in North America, try your local RC Airplane hobby shop. Most RC Helicopters use JIS screws to mount the propeller. JIS-spec cross-head screws are generally marked with a single raised dot or an "X". JIS always fit Phillip fasteners, but because of slight design differences, Phillips drivers may not fit JIS fasteners. (unless the tip is ground down a bit).
Great explanation here, and doesn't just apply to motorcycles. It applies to the sc430 and any other Japanese car. Plus like I said other manufacturers have gone to it too.
removing stuck screws is part of my job. Never heard of jis screws. Only what bgw70 just described
