See this line? Use your hand to follow it down to the power steering pump. Once you see the pump, you will see the little cylinder with the two ears. The lines connected to those ears are your vacuum lines. Use your hand to follow them up.
No matter what, you should replace them. If you order them before you take a look at your engine, you can use their preformed shape to figure out where they go.
Thanks Darryl
so I need to remove my air box and intake pipe to get to really see where these lines go
am I correct?
It has been awhile since I did it, but I believe you are correct about the airbox, I remember when I did it, I could see the parts from the top pretty easy. I know I replaced the hoses from the top.
Watch this video from Scotty Kilmer that will show you how to replace the valve. He will tell you what symptoms you will have if your valve is bad and how to do it if you need to
Thanks to everyone who responded...
i started to do it myself but ...
i have a mechanic that's going to change it for me
one last question...
does this power steering air control valve stick out of passenger side of the power steering pump or
out the bottom of the pump
ive been looking for my power steering vacuum lines but I can't seem to find them
does anyone have pictures of where they are located?
thanks in advance
why do you think it is the ACV, Vacuum?
is the problem all the time?
10mph and 70mph?
its easy to find out if the ACV is good or bad.
just disconnect the vacuum from the ACV and if the steering is harder, the ACV is good.
now reconnect and the steering should be easy again.
if not, replace the ACV.
you could have a bad pump or rack.
perhaps, really dirty fluid.
the alignment could be off.
it sounds like you are throwing money at the problem and hoping for a fix.
BTW, coming back here once a week is not the best way to obtain good help.
One last thing, the PS is much easier on my 2007 vs my 2002...I have never figured out why.
high speed or low speed, it doesn’t matter, the 2002 steering requires more effort.
the tires might have something to do with it.
the 2002 has the Pilot Sport A/S 3s
the 2007 has the OEM RFs...harder tire.
I'm just asking for advice before I throw money at a bigger problem steering is stiff with vacuum lines on or off
again
thanks in advance
lez
good, then the ACV may correct the problem...but it could still be the pump, I also know if the electrical connector is removed you won’t have much power steering.
thanks in advance
Try using Seafoam Hydra Trans Tune, before taking everything apart. I had the same issue on our 07 CRV and fixed it by using trans tune, working fine ever since.
Changed that valve steering got a little better tackling the pump next
thanks for your help
Lex
Hey Lex,
Do you have a Check engine Light on? Did u have your car scanned for codes?
The power steering pump isn't too hard to replace, but it can be pricey. It would be good to know if that is what you need, or if you can get by with fixing a cheaper part.
