Power steering stiff
Old 04-15-19 | 08:31 PM
  #31
LEXZILLA's Avatar
LEXZILLA
No check engine light
Old 04-16-19 | 03:32 AM
  #32
Bgw70's Avatar
Bgw70
Originally Posted by john341
Try using Seafoam Hydra Trans Tune, before taking everything apart. I had the same issue on our 07 CRV and fixed it by using trans tune, working fine ever since.
i might just give this a try in my 2002...plenty of folks out there claiming it works.
Old 04-16-19 | 06:04 PM
  #33
Bgw70's Avatar
Bgw70
I drained then installed about 8oz of the Seafoam Trans Tune in the PS reservoir. Went out and drove it five miles or so...verdict is still out...butt Dino said it was harder to steer....will drive to work the next couple of days until I can drain entire system and refill with proper fluid..
NOTE: not saying it is bad, just no difference, plus this may be normal for a 2002....and I might be spoiled by the 2007....2002 front end parts have been replaced...
Old 05-08-19 | 04:48 PM
  #34
LEXZILLA's Avatar
LEXZILLA
UPDATE!!!!
I had the ACV changed and also had the passenger side lower ball joint changed also steering much better now
Thanks to clublexus and everyone who responded to my questions and gave me advice
Old 05-08-19 | 05:38 PM
  #35
DshngDaryl's Avatar
DshngDaryl
That great Lex, I am glad the ball joint solved the problem.
Tau511
SC- 1st Gen (1992-2000)
02-02-16 07:41 PM
worldforgo
02-04-12 10:47 PM
bdshomes
03-12-11 11:34 AM
Lex*Toy
Performance & Maintenance
03-07-07 08:56 PM
